All fire stick guides in one spot! *Please Read*
Alot of talk on this, so I’m making all the troy guides available updated in one topic pinned for easy access.
Please be aware of all of amazons changes before buying a product or trying to cut the cord. Take a look here as well. Please understand you are limited in customization of your device. Kodi users DO NOT use builds, stick with single addons. Maintain your device always with sticks.
Always search troypoint.com for updated stuff first.
Remote shell app
Best streaming apps to use with RealDebrid.
Buffering info
Complete beginners guide for firestick setup.
Reset firestick and fire tv
How to reset kodi on firestick.
How to reset and factory reset firestick
How to update firestick
Usb formating guide
Expanding firestick storage.
Update blocker method for firestick
Installing vpn on firestick
Firestick remote fixes
Update kodi on firestick
Firestick tricks and setup
Missing icons.
Iptv buffering fixes firestick
Lots of app to use!
Hidden firestick tricks.
Developer Options info
Wolf launcher for firestick
All things Kodi
Important information about dev options and enabling it. For some reason if you dont see or have developer options try this:
Also try resetting your device.
Firetv Users
Device and setting, look for about and click that 7 times for dev options to appear.
Important firestick and fire tv guides for you!
Tivimate guide
Tivimate
Important info about updates and custom launchers
Read the info here.
Updated.
Please don’t try to block updates unless you are postive you have the correct firmware version. I have also added the beginners setup guide. Enjoy.
I was updating all my six firesticks with new apks recommended from Troypoint, when one of them said something like "wait until we condense or check… " It stuck there for over an hour. Re-powered, and it’s stuck on the Fire TV logo, 3 dots scrolling at bottom. Tried everything found online, unplugged, different power cord/transformer, remote. . nothing. Contacted Amazon support they gave similar fixes, none worked. Finally said, “nothing we can do, out of warranty, we’ll give you 20% off next Fire TV device.”
Any one have any ideas how to resolve this and use this fire stick. I don’t think it’s a 4k, but a newer generation. Hate to toss it. Luckily just bought a 4k, and have Onn as spare.
Sorry i havent used a firestick in a while. Not familiar with the issue.
Personally i wouldn’t stay with Amazon devices. They are getting more and more restrictive.
The Onn 4k ($20) is a good replacement but the Onn 4k Pro ($50) is even better and recommended by many here. I have 2 and no complaints.
Good luck, hopefully someone here can help you salvage the device. No need to throw it out if it still has miles left on it.
By the way. This has nothing to do with the Diggz Burst build. You may want to ask your question in a firestick thread. Copy and paste your issue if you find one applicable.
@Miki may move it for you if you cant find one. But it may be past his bedtime tonight… :grin::sleeping:
Fire TV Sticks myth busted
Dec 16
9m
Geo0402
9m
I read this on The Mirror newspaper Uk. Will post pics as not sure if link allowed. Thought was interesting read.
So, they’re paying this guy to tell them what we already know.
Is there any easy way to to clone a firestick4k with all aps and settings?
No. there isn’t.
I have not been able to find this info so I am hoping this is the right place to ask. I am trying to add the paramount plus app to my firestick 4K but the App Store says it can’t be found. Ant ideas about where else could get it from? Thank you!
It does depend on where you are. It may not be available in your area.
https://www.apkmirror.com/apk/cbs-interactive-inc/paramount-fire-tv/
Peep’s still use firesticks? Amazon is an asshorse with their restrictions…onn is much better
Can you VPN the Onn
Welcome! You absolutely can use a VPN on the Onn 4k boxes or the Pro. I have used a few different VPN brands on them successfully.
welcome
I am in TN, so I don’t think it should be an issue. I was hoping there would just be a downloader code but I will try using silk to get there. Thanks for the help!
Why would someone go spend more money to buy something else when the firestick works just fine?
