Kodi guides and info
Hello, this is just a mega topic to get all your kodi info.
Please make sure to follow all of troypoints guides on kodi. I will have some references here.
Biggest thing to remember is your kodi version and the build/addon you want. Make sure they are compatible. 19+ is the matrix stable Make sure your build or addon is updated for that version.
Reworked kodi setup guide
Supercharge kodi
Skeleton crew v2
Must watch video for kodi setup.
Speed up kodi and the crew guide.
Crew not working? look here!
Colon key missing
Custom kodi build.
Adult addons
Best builds
Best addons.
Layout guide
Checking error logs.
Install kodi on firestick
Mega resources guide for kodi.
How to use kodi.
Multiple kodi builds within one.
Install kodi on any android box
How to disable oauth msg.
How to uninstall addons.
Kodi sports addons
Complete beginners guide for kodi
Kodi forks
Best info for kodi with all your links.
Make sure to update your kodi addons regularly
Always check you read debrid subscription time
Seren keeping track of real debrid
With seren make sure you are going through the guide entirely.
Here are most common problems people are having troubles.
  1. Using a VPN not compatible with Real-Debrid. If you’re using IPVanish VPN, you have nothing to worry about as it’s 100% compatible with Real-Debrid.
  2. When configuring the Seren add-on, you aren’t taking the extra step to install the necessary scraper. You must read the entire Seren guide…all of it.
  3. You’re making a mistake when typing in one of the addresses for either the Seren addon itself or the scraper. Take your time and double check your spelling. One wrong character in either of those addresses and this won’t work.
  4. Your Real-Debrid account has expired. Keep in mind, you must have a premium account for this to work properly and they don’t notify you when your account has expired.
This as been addressed in the advisor as well.
Will update as more guides are available.
This should be all you need for kodi, that resources guide has everything. I wanted to make a all in one topic on this to help everyone. Remember to take your time with setup.
Thank you
@Jayhawks659
@TROYPOINT
@anon44985237
@anon8121885
And anyone else for there contributions. Pm me if I missed you.
Well I have the visual proof as well as tech results that it does provide me with the full speed my ISP provides and at times better than what they claim to provide me. For me it is possible. Do I know how? Not really. Do I care. Also not really. As long as I get good speeds, can surf the net, send and receive e:mails and in general enjoy my streaming, I am a happy camper. I have had subs with the top VPN suppliers and Proton works for me and their claims are honest. YMMV.
It is documented. It is on line, and there are those here, like myself who use it, with the same result. YMMV. The only reason I’ve seen that more don’t use it is it’s more expensive than say SS and does not provide unlimited connections. Even their free VPN is rated as one of the best, but the servers often get full due to the “free”, aspect.
The information is out there and there certainly are forums, ya just have to want to research and read. But as I have mentioned, it doesn’t matter as long as I get what I paid for. Everyone is entitled to believe what they want and who am I to disagree? Have a buffering free day @Avid08. I have more important things to think about.
Well be my guest and do the research. Even take a look at the independent audits. I certainly won’t be doing your work for you.
It can and does speed up my connection. Of course pings can be improved via many methods, even without a vpn. I can improve throughput just by using a different server. We use to tune our own connection via simple things like MTU. So what experts can do with coding alone is like magic these days. Whatever tests you want can be done. But this is derailing the thread so I am done discussing this. Won’t ever sway your opinion no matter what proof is given. Have a good day.
I did. The screenshot. But as I said I won’t help you get your answers as you are already predisposed to find anything I post as untrue. I will not participate in a futile effort nor will I continue to derail this topic. All that matters is I’m happy with a product that I know from years of use and research ,simply works and does what they say it does.
Well Reddit does say it works and there are blogs with ppl who say so. You don’t belief what is on the internet, but do some reading and I can go on ad nauseam. The following was even 4 yrs ago, so imagine how much better the tech is now.
Boost VPN speeds by up to 400% with VPN Accelerator | Proton VPN.
Well I know there is no sense in discussing this with you as even the visual proof would not matter to you. I certainly am not going to give you a copy of my ISP contract showing the speeds I pay for 150Mbps down, and then invite you to sit right here and see the results like the one I posted. Their claims are legitimate and there is absolutely no need for them to fabricate or lie about their facts. They have been around long enough to get a good rep with giving honest and truthful facts. Works for me and no other VPN supplier I’ve ever used have provided me with the stability and speeds I get with Proton.
No 8K channels? Say it isn’t so. My streaming life will never be the same now I know that, well if we’re to believe you. GL2U
Oh btw this is the answer my AI gives:
Yes, there is at least one dedicated 8K channel, the NHK BS8K channel in Japan, which is considered the world’s first 8K television channel, broadcasting movies, documentaries, and other content in 8K resolution
Lol. I know what was said and you have your facts slightly askew. But again this thread would be hijacked further. I never trust AI I just used that as an example of info that can readily be obtained if the time is put in. But like the fact you laugh at the %400 speed improvement. You really need to read an entire subject as it’s not an unreasonable claim given the specific examples and circumstances they use. Look you like to argue and to cajole and I have obliged you more than I should. I am done. Be well @Avid08 and enjoy your streaming.
You just like to think you’re right and in this case you plainly aren’t. You haven’t done your research on Proton and have clearly misunderstood a lot because you have read a little. So once again I am not continuing this arguement just to amuse you. Have a great day and good luck with your learning, I know I will with mine.
1000000749
You have latched onto this %400 figure and continue to fixate on it. Fact: some ppl pay for 50 Mbps down from their ISP, but their system only gets 10 down. Certainly not the ISPs fault or maybe it is. So using Proton VPN and other Proton products certain improvements can be made to improve certain aspects for better speed. So how much exactly is a %400 increase in this scenario? Very achievable. So you are implying that a reputable company with amazing techs and top line staff is lying? Tell ya what, I never ever claimed I get such speed improvements and stand by my facts on my system and oddly enough I believe and trust that Proton knows more about their products than you do so I’ll believe them way ahead of you. So you believe what you believe and I’ll do the same. The bottom line is I get a better, more stable, and faster experience using Proton than without and as long as I get good streaming with minimal buffering using Proton, that’s all I need. So all this back and forth is a waste of time.
