Help. Nothing playing
I’ve uploaded a few of the recommended apk’s onto a fire stick. I’ve never had an issue before. But I just can’t get anything to play. I’ve got real-debrid on them. But nothing will play.
Any ideas of what I’ve missed??
Thanks
Kodi mega guide.
Please read this
Before you post or ask about IPTV, Free links or any of that info without a RD account you need to use our search function as this info is HIGLY talked about with tons of info. Bottom line is if you want to use kodi and get free links or streams without using RD it wont happen or work well, they come and go. The best option to use kodi is to pair it with Real Debrid which is covered below.
Welcome to the community. As a newer user please use the search as this is a common issue/problem.
