How to install kodi builds with usb stick on my fire stick?
Tutorial on installing kodi build on kodi 19.3 on firestick with usb stick
Welcome @connieboy63
Do you mean you’re using a USB stick as extended storage on a Firestick or do you want to install a build from a zip file stored on the USB stick?
@connieboy63
As a new user i encourage to take a look and use the search functions.
I have a kodi topic wirh every guide.
Kodi mega guide.
Firestick guides for usb
Yes, I’m using a firestick 4k with usb for added storage. I was unsuccessful installing build on kodi 19.3. I didn’t know is the usb on the firestick was the problem.
Have you formatted the USB to FAT 32 as per the guide and is it showing as external storage in the Firestick Settings?
I’m wondering why you are even trying to install a build from a flash drive? Normally you download Kodi and then install a build by adding a repository and opening a wizard. The build would install in the same place that you installed Kodi initially.
