The Crew not working Firestick 4K
The other day, the Crew stopped working so uninstalled it and when I try to download from the zip file, it take a couple of minutes and fails. I have deleted all adding, deleted Kodi and ever set my Firestick 4K back to factory and then reinstalled everything. And the Crew still fails to load the zip file.
Is anyone else having this problem?
@Richie1863
Hi welcome to the platform
Here are two links to guide you how to restore or reinstall The Crew add-on.
How to Install The Crew Add-on Firestick
The Crew add-on Not Working
Thank you. I have tried both of these, I run into trouble when I try to install from zip. It errors out every time
@Richie1863
Hi Richie did you allow unknown source?
If not go to: Settings> System> Add-ons to the right Unknown Source must be on.
Check the entered repo url for typo? Otherwise Retyped again.
Are you using VPN. This is a must to protect you privacy.
Give it try and let us know
I just downloaded it from the main site and it loaded fine
yes. I have uninstalled The Crew and reinstalled it and it would not reinstall. 4/28/2022
The Crew used to work. No matter how many times I try, it fails when installing from zip file.
Glad to see I’m not the only person with this problem.
https://troypoint.com/?s=the+crew
I have tried all of these several times. I can down load the zip, add it as a source, however when I try to install from zip, it fails.
@Richie1863
The crew does work and is still maintained. Make sure you have enough space.
Kodi mega guide.
