⁉️ Stremio Fixes - Most Common Problems with Solutions
Is the Troypoint Toolbox still an app you can download and update or is Web based only now?
It’s never been an app and it is accessible from the downloader app or the web.
Thank you I have it as an app 5.1.0
Have you added your debrid services api kyes to the addons you have installed as you would need to do this to make things work correctly
I believe you may be referring to the old RAI, which was shut down in favor of the Toolbox. If you still have the app, I can’t imagine anything still works? Just Trust in Troy’s Toolbox which is web based and you can access it with a simple url.
In regards to Stremio live channels going dark after 15 seconds:
I found the fix or workaround for the issue of the screen going dark. I had the same issue on both my firestick and Onn. I found that installing “VLC Player” ( the one with the orange traffic cone).
Only the SD versions will work for the live TV channels and you have to select “external player” and then “VLC Player”.
Or if the stream starts automatically, pause the player and click the external player and select VLC Player.
I have been doing this for about a month now and haven’t had an issue since. This works for all the USA Live Channels.
Hope this helps
Thank you. I got Downloader, Stremio and Bootstrapper working. Stremio has no content, or I have to pay for it or rent it. What am I missing?
I have put the api code in the add on/’s but still nothing. When I click on a movie it shows RD+
Ok thank you. I’ll have to figure out how to do that. Do you add the vlc player as an Addon in Stremio?
And RD+ is the RD Cached source.
I prefer Just Video Player which you can download from Troy’s toolbox :toolbox: . Then in Stremio in the “advanced”section choose default player and choose VLC or I prefer external player. Then when you start up a vid a popup will appear asking which player you want to use if you have multiple ones. Highlight the one you want and click ok. I also choose just once, instead of every time, as I test many players. I personally do not like VLC and it has caused me problems in the past, so I go with Just Player that I have installed on my device.
Torrentio is down for me. Also tried to add the addon into my AoiStreams and get an error. I do not recommend this addon due to all the recent issues.
Torrentio is still Working great for me in the Duck Streams addon. PM and TB showing cached results.
Like @TXRon said - the TROYPOINT Toolbox is accessible from any web browser and works best with Downloader - TROYPOINT Toolbox
I was able to add it back in to my AioStreams and links are working again.
Is Duckstreams down? Not working for me in Stremio.
Duck streams is providing me sources.
Thanx again @Miki. I had problems with a series with lip movement, voice sound and CCs all out of sync. Just Video Player cured it all. It’s my new go to. If you have problems getting videos to sync, give Just Play a try.
