⁉️ Stremio Fixes - Most Common Problems with Solutions
Tried telling Surfshark that many of their IP’s are being blocked, but they seem to not understand. Just kept telling me useless things to try. Spent 3 days trying to tell them that they need to change/expand IP pool. Maybe Troy can get them to comprehend that there is a problem. Found also that Surfshark prevents Stremio bootstrapper or update for the same reason. Have to turnoff VPN, do updates then turn VPN back on.
@Outside62 My Stremio works fine EXCEPT for Torrentio as it gets blocked by Surfshark unless I monkey with it which I’m done doing,
I get Duck and Comet links out the wazoo. I use Kodi most of the time anyway but I like to use Stremio for fun occassionaly.
Torrentio links work perfectly fine with Kodi and I never have to mess with Surfshark using Kodi
I suggested Just player to Troy and he put it in his Toolbox. It also does auto subs once you configure it and Troy says it does a great job on the catch up as well. I don’t do that but of Troy says it’s good then it’s good. :wink:
I take it, it’s just me. I’ve searched and scrolled through this thread. Duck streams no longer shows up on anything anymore. Everything else still does. I have looked in the installed addons and it’s in there. When I click config on it, it pops up 404 page not found. I get that with surf shark on or off. Just trying to figure out what’s up with it.
Or did I miss something and it doesn’t work anymore? Thanks in advance.
Duck Streams up and running for me.
I would delete the Duck Streams addon and redo it. It’s working fine.
That fixed the issue. Appreciate it :+1:!!
