Problem installing Crew
Crew stopped working. Tried to reinstall and received error message that the required additional addons were not available. Tried to load a different app with the same result.
@dogluvver
Kodi mega guide.
What error are you getting and what device?
Using Firestick 3. I have used Kodi for a long time and always follow the video or written instructions when installing something new.
After downloading and when trying to install, there are a number of dependant files that are required. I get a message that the file(s) are not available.
What stopped working with the crew and which ver?
Failed to install dependency” is a common error with the Crew (and some other addons). Usually, just hitting “Install” again will cure the problem.
I think it’s something to do with their server capacity
Thx. Tried to install a second time and it appears to be ok now
