đŸ“ș Norofire App Installs Both Sportsfire & Streamfire - Fixes Fire TV Blocking Issues
Is there more to come?
Absolutely. I can assure you that @PapaS will have Easter cake for you as well as on your anniversary. Oh sorry, were you referring to more apps?
Yes more apps and the movies that I would like to watch are all blocked
Darn it ATTA BOY MIKI !!
Maybe
What apps are blocked for you I may be able to help
Use Stremio my friend. Watch Troy’s video. Spend a bit of time and get a debrid service. Learn how to integrate them in some Stremio addons. Please use the site search and read read read. So much info here for you to feast on.
I agree stremio is the go to app
Well in all fairness to others, I would say that Kodi or Stremio. But certainly for those learning from ground zero Stremio can be easier IMHO.
Once it’s set up it’s so easy that’s what gives it the edge
And one more thing happy Easter to you an your family
That is true but an another advantage for me is because my add-on, library and other data are stored on the Stremio server it means they are available on all my devices without having to set up separately on each device.
tried installing Sportfire on my fireTV thru NORO today 05/04 but got a “error parsing” error
Try clearing downloader cache
Just installed it with the downloader code, granted permission and turned on the install unknown app for it. Working perfectly.
nope, tried again - same result norofile won’t install - parse error
Tried both the code for 6185176 and the 7446077 then the direct download same result
nerofire 1.0.0. won’t install
It happened to me a few times before it loaded I deleted it then deleted downloader cach an data then reloaded an after a few tries it loaded
Just installed Norofire app, checked allow apps to be downloaded and then tried to download sportsfire and the sister app. I clicked the permissions on and then tried downloading the sportsfire app, the app showed it was downloading and then didn’t, so I reset the app and tried again and it didn’t download, is anyone else having trouble like this.
Yes I have maybe site is overloaded app loads to around 17 mg the returns to app. It may depend on what Device and how old
DOesnt work on firestick for the moment I guess. IT installs norofire but only for android.. From there I managed roninstall noro on the firestick, accepted the terms and conditions, allowed permissions.. tried to install both sportsfire and mediafire but to not avail on my firestick. Troy, any work arounds. ???
The code 7446077 works to get us to a download page but then says to use downloader code 7446077. Go figure ?!
I got sprortsfire to work but not streamfire on a firestick using noro
