📺 Norofire App Installs Both Sportsfire & Streamfire - Fixes Fire TV Blocking Issues
Since yesterday evening, Streamfire gives me the error.. oops can’t connect to internet. Everything else working fine, including their sister app sportsfire. Hopefully it’s a temporary thing. Was just checking to see if this was an everyone problem. I haven’t tested it on another internet provider yet. I am on spectrum and security shield is disabled. I will go over to my buddies house on ATTT and check it
Just checked, not working for me either. I get a spping circle says “Trying to connect”. I even changed my ipvanish vpn server. Likewise, hope it only temporary. This is my main backup for live tv
  • App Version: The latest version is v1.2.3, released on February 13, 2026, which includes fixes for slow response times and adds new channels.
  • Installation: The direct download site streamfireapp.tv is no longer functional. Use the Downloader Code: 6647940 to install or update the app via the Downloader app on Firestick or Android TV.
  • Common Issues & Fixes:
    • If the app crashes or won’t open, uninstall and reinstall using the Downloader code.
    • If you encounter a “parsing error” after updating, reinstall from scratch using the latest code.
    • Some users report issues due to geolocation blocks—using a VPN (e.g., NordVPN or IPVanish) may resolve access problems.
    • Clear app data, cache, and force stop via device settings if the app freezes or fails to load.
are you on spectrum inernet?
ATT internet
yep its down then..been a trusty app.. anybody got any back ups for live TV other than IPTV?
thanks for the info!! That is the downloader code I use. Just installed it on an ONN box fresh out the box. nothing else loaded on it. The usual disabling of playprotect done. Same message. I hope this isn’t a sign of things to come.. the “whomever” forcing APKs to shutdown
I’m going to keep checking over next couple days. Might just be a glitch in the app.
Might want to give 1 Pix Media a try. It not a clean as StreamFire. TP did a guide on setup. I don’t know how to link guide to response. But, you can do a search to find guide. Downloader Code for 1 Pix Media (790093)
Checked and its working on my 4k max
Same happened to me can’t connect to internet was spinning circle.
Removed app then reinstalled but nothing now.
On or off the VPN so it looks like it is gone for now.
Was good when it was there.
1 plus media seems to work good. only after the wuffy player was installed.. I missed that step trying to be quick lol It is designed to be a mobil app, and therefore runs kinds sluggish on my ONN (I assume that is the reason) Maybe they will release a tv version.. I will keep playing with it later today until streamfire comes back this after noon :crossed_fingers: hopefully
Downloaded the 1.2.3 version on my ONN 4k Pro. Virus total show 19 red warnings, so I uninstalled quickly .
This is weird on 4k max Virus Total is green. But, on ONN 4k Pro its 19 red warnings.
LiveNetTV isn’t working today either (on my android boxes). I’ve been using this for years. I think it uses the same sources as Streamfire.
Surprise Surprise another Crappy APK bites the dust. :rofl: Can’t talk much about it here (Forum Rules) but my friend Amber might have a low cost solution that works great. Solution is here if you search
Sportzx is the best at the moment
Nothing posted on their Telegram page. Give it some time. They are usually good with that.
Well, Streamfire appears to be back up! (At least for me).
Streamfire 1.2.3 is back up and running. I had to redo my watchlist.
I am having the same problem with Sportsfire with only one of my ONN devices. Turned it on and the app was missing and also somehow the big G. turned back on “Play Protect” and the app was gone. I tried multiple downloader codes that all failed and were probably outdated. When I turned off Play Protect and used the latest code I had 119368, it showed installation complete, the app was on my homepage but when I try to open Just a black screen. Is there a current fix or a newer downloader code. I’ve got the same setup on another ONN device and 4 sticks so far without incident. Tried SS on and tried it off without success.
No it’s still there
