Got this notification today anyone else received it
Yup, just got the same popup when I loaded Streamfire. Wonder if this will bypass the Amazon blocks?
Not tried yet
Maybe Troy can check it out just in case
Downloader code is 6185176 and both apps working good on my Buzz P6. Thanks for posting.
Good news
I havenât tried this app yet but from the looks of things, you can install both of those apps through the new Norofire application. Sounds similar to an app installer of some sort.
I just used it and you must grant permissins to install sportsfire and streamfire. Both are working great.
App code for NORO ânot parsingâ on Firestick.. No idea how to workaround.
Maybe itâs only for some devices
I was having no luck trying to install both Sportsfire & Streamfire using the app clone method for 3 days of trying for some reason they would not open on my fire cube, I gave Norofire a go followed there instruction and done the deleting of both app and run this install at it work both apps installed and are working fine on my fire cube
Working so far. !!! 4/5/26 10AM EDT !!! Thank you!!!
Does this come with icon on main screen cause when ever I want to watch something on stream fire or sports fire I have to go into apps setting the open it through there instead of clicking icon on main screen where all the other apps are.
Yes icons show on mainscreen
I have everything installed and working just fine. My question is, does it install apps and if it does can some one tell me how to do it please.
I am the old man that is really enjoying the learning curve!!
I cannot believe I was so fortunate to run across a great bunch of real people that jumped on board with Troy and helping people like me that cannot find his way to the bathroom ( CHUCKLE )
GOD BLESS YOU ALL
I am talking about apps like the ones that have movies on them
Not so far itâs just the two apps
If you want specific apps for movies etc. then just use the site search to find info on them, and to access special videos and categories for more advanced info.
The above is just an example of what Troy provides to help all levels of experience.
Norofire is working on Tivo 4K boxes as wellâŠ
Thanks go out to the designersâŠ
