hi all.im new to all this and baffled.i downloaded kodi (no problem)but theres no movies tv etc.it says my library is empty.i dont know what i am supposed to do next.can anybody guide me thanks dav1d49
Kodi mega guide.
Read up on our guides first
hi kodi dosent carry apps that you require you have to add them yourself
Kodi is just a media player. The content is in the addons and the sources within those addons. Lots of articles on the Insider and Troyâs main page to read. We talk about Kodi and the addons everyday it seems.
Yes you need addons to watch movies and TV shows, like Magic dragon, Promise, Homelander, Asgard,.
so do i type these add ons into the search bar.thanks
See that guide above that @AMD237 posted for you? Think of KODI as a media player however you need to install an Addon(s) in order to play content. You are also going to need a paid debrid service to get any working streams but letâs hold off on that for a second. I would suggest going into that guide and installing The Crew Addon as that is one of the most stable for a long time now. Please follow the instructions in the guide. Thereâs a bit of a learning curve at the start with this stuff but then it will become easy.
Guy ! You sound like a newbie . You have alot of reading to do .
Troypoint website has links for the add-ons in the posts above, for extra guidance look on YouTube how to navigate around kodi.
Before any of us help you, please read all the guides. They will inform you of what to do
thanks mark.wrote all that down (didnt realise there was so much lol).ill give it a go.cheers
yes.i did put that in my original post.thats why ive been asking for advice.
yes ive been on troypoint.one of the issues ive got is sometimes you have to scroll down a list of programmes to find the one you want but the cursor on the remote has a mind of its own.cheers
Iâll echo what was said, TPâs video guide is easy to follow and will get you up & going.
Two things: Most of us definitely advise spending a little money on a VPN.
Second, spend a little more and subscribe to Real Debrid (RD for short).
While the guide is a great âpaint by numbersâ way to get started, itâll save you time in the longer run if you know what & why you do each step.
-The settings>File Manager>Add Source steps are to prep Kodi to access files, whether via the internet or from a USB drive. Youâll do this each time you try an addon or build.
-Carefully check the spelling & capitalization & punctuation as you âEnter the paths or browseâ.You wonât hurt anything, but a mistake means that youâll have to repeat this step.
-The âEnter nameâ box can be filled in with any name that you choose, no need to be as careful.
-âInstall from zipââŚthe source is sent via a compressed file. This will arrive very quickly as long as youâre connected to the internet. It will also âunzipâ the file very quickly. After itâs unzipped, the downloaded ârepository (AKA:repo)â contains one or more Video add-ons.
-âInstall from repositoryâ lets you select which add-on that you choose. In the team-crewâs repo, there are several choices. If you want both The Crew & Nightwing add-ons, you donât have to repeat all the steps. You just need to go to âInstall from repositoryâ. This step can take a few minutes. Grab a cup of coffee or a beer.
Donât worry if you forget to turn on âunknown sourcesâ at the startâŚKodi will prompt you to do so when it is necessary.
Once you know what you are doing and why, the only thing youâll need to install any other add-on is the address for the link of the repo that add-on is available. You wonât need to follow a guide again.
This will be somewhat controversial around here, but for a beginner I would advise sticking to one or two good add-ons and avoiding âbuildsâ. Even the best builds have a lot of stuff going on to learn to navigate. And they are larger than a simple addon, which is a consideration with Firesticks. Once you have your feet on the ground, then you might want to experiment with a good build.
For a beginner, Iâd suggest following TPâs instructions for installing The Crew add-on. Like I said, once you have that repo on your Firestick, youâll have easy access to sevrl other addons to try.
thanks,much appreciated.ive had a look at several vpns but how do i know when ones working.cant see any signs that its on cheers dav1d49
VPN Monitor Dot on Firestick/Android (VPNSafetyDot Alternative) (troypoint.com)
How to Install VPN Privacy Dot on Firestick & Android TV (troypoint.com)
You could use one of these Dots to show you the VPN is active.
I have been using VPN privacy dot. I like it better than the old safety dot.
