M3u playlst with EPG
I have done a search for m3u playlist and found some but I can’t find any wih a EPG . Where can I fnd a M3u list with a EPG .
EPG’s are probally the hardest to find and when you do will it work. Very illusive because of always changing and not being updated. You can poke around here for a few. I find the combined epg the best.
Apsattv.com Streams page
Many don’t have an EPG. There are sources available that provide EPG’s and it’s trial and error to get one or even a few that will populate a TV Guide for your channels within your playlists. Best bet is to 'collect a good few EPG’s that are updated regularly.
This link may help: GitHub - iptv-org/epg: EPG (Electronic Program Guide) for thousands of TV channels collected from different sources
Hi @scooterboy952
Check the thread that @Miki and @Powerfader have posted. Lots to look at and try out. You can find them using the search feature above.
Good luck.
Thanks for all the m3u list . No EPG but the list are working good .
The link with xml.gz at the end is an EPG. XML is the file format for EPGs and the gz on the end denotes a compressed file. The following is the EPG for Pluto. You can enable this on every playlist you have, as it may have identical channels to other playlists, and load the missing channel epg in that playlist, or at the very least will give you an option to choose that channel epg when doing an EPG search and loading an EPG for a specific channel, which you can do in the TiViMate settings.
https://i.mjh.nz/PlutoTV/us.xml.gz
Doing a search on google and you will find all sorts of sites with EPGs you can download and install. Now installing free playlists like Samsung, Pluto, plex etc. there will be an epg added automatically for you. The following is an example of what you can find.
Now you just have to learn how to enter these and where. I can help with that if you have a premium TiViMate account as that’s what I use and am reasonably conversant with. PM me if you prefer some one on one assistance.
I have premium and put the epg code in the right place but didn’t work . Will try again .
Which epg are you trying to load? I’ll try it out for you and see if it’s viable. If not what playlist do you need an epg for? I can find one for you.
https//iptv-org.github.io/iptv/index.nsfw.m3u
https://cutt.ly/DSr95 combined
these or the ones I’m using .
Ok so the EPG for that first list is :
https://iptv-org.github.io/epg/guides/ad/
andorradifusio.ad.epg.xml
and for the second list is
https://cutt.ly/DSr95Combinedepg
I just checked and it is still an active playlist. Be sure to enter that exactly as I’ve shown.
So the first list is around 7300 channels. The channels seem to be working and I can update the list. The EPG doesn’t yet load. As I now have almost 20,000 channels it may take some time for the EPG to update and load. Ok I just went back and some channels are now displaying an EPG.
I added those two epg playlists to the cutt.ly and github.io playlist and could not get anything in epg .
I go to settigs - epg - add epg to the playlist click done - go back to channels then go to the playlst where I put the epg list and nothing is their . I guess Im doing something wrong .
Both EPGs worked for me. The combined list loaded more channels. I deleted the 7300 channel list as a ton of channels are foreign and of no use to me. But I’ve had the combined one for a long time and it works.
Ok I just noticed what you said. You do not go to EPG to enable them, you go to settings>playlists> click on any playlist and scroll down to EPG sources, click on it and then your epg lists are shown and you enable any you want using the “radio” button.
I did what you said . Went to Play list added epg list to matcing playlist then clicked on update then it said update succssful but still got no epg . What do you mean by radio button ? I coudn’t find one .
it’s the button to the right of your epg to enable or disable it. I don’t know why you aren’t getting any epg, I got it on both your lists although it took a few minutes to load. The bigger the playlist the longer the EPG takes to load. Some can take 10 minutes the first time.
I turned That button on but still no epg . I don’t understand I bought this premium app and it don’t seem to be any better than the free verson .
You need to give it time. EPGs take time to load sometimes 24 hours. Tivimate has nothing to do with epg load times.
OK . Should I leave the app run a while ?
