Kodi Matrix 19.3 "Adults Only!" Password Issues
Totally understandable - we’ve all been there. From the home screen of xenon click the xenon matrix button which takes you to the settings menu - go down to and click addons then click my addons at the top of that menu, scroll down the next menu to video addons which brings your video addons that are installed, scroll down that menu until you see videodevil (near the bottom) click videodevil icon to get addon information, there is a menu on the left side - go down to versions and click the 1.8.21 xbmc adult addons which will install this version. For some reason mine got switched to another version and thus the pw wouldn’t work. Worked for me but no guarantee’s.
Thanks Lefty; I will try it…
I don’t have any Video Devil add-on within that particular page at all Lefty. Maybe its in another place or on another build besides mine??Maybe I need to download it from somewhere? Is there any way or place to browse and download new add-ons from my particular build? Like I said; I’m running Kodi 19.3 Matrix along with the Diggz/Xeon Add-on Repository.
I am running the same setup - not sure where to go from here. Maybe someone else can chime in - good luck.
Sorry you are absolutely right 1234 does not work. I have only recently upgraded the Diggz Xenon build to 7.6 and I hadn’t tried to log onto the adults section. I’m sure this used to be protected by the Pinsentury addon but I don’t seem to able to located that any more??
Lots of vids to watch, even if you don’t have the exact addon or build that is in the vid. A build is like buying a top of the line Hummer, it has all the bells, whistles ,and do dahs anyone could ever want. From satellite radio to air conditioned seats, now you have to learn how to use it. Add ons are like having a stripped down basic hummer and then you add what you want. So it comes with 4 tires and a motor, now you find you want music so you add a stereo, only thing is you have to learn how to get your favourite station. So watch these vids, grab a note pad and pause often to write things down.
Have fun and STREAM ON.
I put anything in for a code and it works.
Hi everyone
I’ve been trawling the internet and I have come across this solution to the adult password problem
From the home page move to add-ons and click
Click on my add-ons at the top
Scroll down to Video add-ons and click
Scroll down to Super Favourites and click
Click on Versions
Click on the top option… Version 420.2.1.0
This will update super favourites then the password 1234 will work again…
This works fine for me Hope it works the same for you Guys
Ps many thanks to Rick
Just followed your fix and it works perfectly many :blush:
You were exactly right Gray. After being inspired by leftyaxe yesterday I decided to go into the add-ons section instead of the Xeon area and gradually found and fixed my problem doing pretty much exactly what you directed me to do if I remember correctly. Thanks you for the instructions though. I saved your post on my computer just in case I might need it for any future reference. I’m learning. Thanks again for your assistance Gray. Good looking out.
Really? I’ll have to try that now that I know my old code works. Interesting.
Hey there, how do I determine which version I am running. I did manage to do a search from the add-ons search and, found 3 media sources-videodevil apps. Just don’t know how to verify which is on my device at present. TIA!
choose 1.8.21 xbmc - worked for me
Thx again. Got it working now. Just have to remember, it’s in add-on section… Thank you again.
Thank you! Worked great!
