I can’t seem to find any videos to install addons for Kodi. I know there are installation instructions, but I prefer following Troy on his videos. Does anyone know how to access these videos? Thanks
put this in your internet search engine
toypoint kodi install videos 2021
K, thanks have been away from this for a while.
You may also want to check out the TP Rapid Install App as well. In addition to the install apps section, I believe there are instructional video’s on a separate tab. Kinda a “one stop shop”. Not sure if you have or not - if not input the following address into Downloader.
Hope this helps
TP Rapid App installer is a great place to view how-to-videos, however some of the vidoes are not currently playing and giving an error message. Has anyone else experienced this issue.
Just checked back on the Rapid app installer and it is now working fine. I should have checked before I posted early as we all know this movement is fluid.
Thank you very much.
Thank you very much. again!
There is an entire topic on this.
