Do you Patrons have any Android-based streaming box/stick reviews that you would like to see from me?
I try to stay away from the cheap China boxes that are all built the same, with the crappy IR remotes. But, I will definitely do them if there is some quality ones like the Ugoos AM7.
Please tell me in the comments if there is something you would like to see. Obviously, I can’t get to all of them but if there is a common need for one, I will do it!
Alot, i mean alot are cheap china knockoffs with horrible software or android builds, the ones you cover already are probably the top. I wish more quality boxes like ugoos would get a android tv os license, that would be steller. Amlogic cpu based boxes not all but some are pretty good. This apparent chip shortage has made it hard for us to get updated shields or anything you reviewed but with more ram space and cpu power.
But my vote would be for the fourmler z10 pro max, its been updated with 4 gigs of ram and 32 gigs of internal storage which you can expand pretty easily.
It has down sides, cant root it, customization lacks. But its a very simplistic setup with very little errors. The remote is a ir remote but im not sure of its been upgraded to bt or not. It controls my tv and everything els too.
Its worth a review, but i hope others come in and suggest others as well. The reviews you do are very good and help everyone decide on a quality addition to their home.
Thanx for all yor knowledge & expertise & thanx to all the peeps helpin out in here
Im tryin to find more info on the X96 x4 pro droid tv box… running 11, amlogic,4ram, 64g
Got one & am stoked with it but dont see a lot of info on it & would appreciate your opinion
Looks like a great device. Only thing I would suggest for that is possibly getting a better remote as that looks like one of those IR jobs and maybe change the launcher to Wolf if it allows for that.
Speaking of air mouse. How 'bout a comparison of the top mouse/keyboard combos. I personally use logitech MX mini keys with a MX amywhere 3 mouse and while its nice it is expensive and I have since found similar options that are much cheaper. My reason for my setup is I can use the mouse/keyboard on my pc and the tv box at the same time. So maybe a review of options avail for the budget minded with simplicity as the focus. ???
2 devices worth reviews by Troypoint are the Ugoos AM6 B Plus, which was rated right behind Nvidia Shield in 2021 with benchmark score of 190,000 and the Buzz TV 4500 XRS, which is less expensive than the 4900 reviewed by Troypoint. Both run off android 9 O/S but are excellent devices. These boxes are still available but only the Buzz TV boxes are available off Amazon.
Speaking of a MOUSE TOGGLE, how about instruction on how to configure the new Android mouse included in RAI. Slightly different configurations based on device. Saw a YouTube on TiVo, Google Chrome & Nvidia…each configuration slightly different
Toggle mouse is one I also am interested in and any good streaming device that is simple fast and has lots of storage, I appreciate all of your reviews !
