Wow. That’s new. Tx for the info. Much appreciated.
I’ve been checking out a number of the movie apps…of the 1/2 dozen or so I’ve tested…Tea & F+ are the 2 I’ve kept. Will be dumping the VOD with my iptv service, so I’ll be using one or both of these apps a bit more. You’re right…the F+ is pretty comfortable to move around in…
I authorized my RD but don’t see any links in F+. Have to clear stuff up and reboot and see what happens. The sources it did find worked well and had a good variety.
Copy that…never used RD & probably never will…but never is a very long time, so…who knows. I watch very few movies & watch the tv shows when I miss them live…every now & then I’ll run across an old series & watch a few episodes…I’ve become very picky & hard to entertain in my curmudgeon years…
I still find Stremio superior in every way. But F+ is a fairly good backup.
I actually put Stremio on my laptop & fiddled around with it a bit…but never got more than one link to show up for any of the movies I clicked on. I have at least a half dozen add ons installed so not sure what the problem is yet. I’ll probably fiddle with it some more & see what happens…I’m sure I did or am doing something wrong…but that’s par for the course these days
Install torrentio without adding RD. You will pull tons more channels
open up addons in stremio then click the search and enter the following>
https://danamag.github.io/stremio-addons-list/catalog.json
Then enter and you’ll find torrentio in there. Fill it out and skip the RD and then install.
Roger Roger…I’ll give that a shot in a bit…gracias I remember torrentio being mentioned by you before, now that I think about it…
I love it with rd it’s almost all I use syncler is right there too
As the saying goes: Well there’s yer problem… Tons of links now, so I have yet another app to play with. After I pop the hood & piddle around with it some more I’ll report back…one thing I did notice right out of the gate was the casting abilities…clicked on the casting button & it asked me where I wanted to cast to…my KM6, my ONN or either of my home mini speakers. Any apps I put on my puter via Bluestacks, I haven’t seen any ability to cast to the tv…so this is pretty cool if I want to use it.
I’m glad it worked for you. In the latest version Trakt is now in the settings as well.
Have fun and STREAM ON.
Here’s my setup for 2nd gen firestick, Cinema( still working ) Kodi, The Crew, and Smarters Pro. My 4K Max, Kodi, The Promise and Tivimate Use Redbox occasionally.
With Real- debrid on all
lol. Hey you know I love helping my friend. So if you need more or are curious about other stuff, I’ll answer your questions honestly.
Have fun and Stream On.
Indeed Thank you very much for all of your help! and all of the Insiders !! you guys are the best!
This is another different link for Redbox if the first one didn’t work. Just remove the brackets around m3u
https://github.com/yadzio/freelivetv/blob/master/redboxtv.(m3u)
Me to. Use to be my go to for channels and sports
