if you have click on that connection, scroll down and click forget. Go back and re setup
Hi @TXRon,
Tried to send you a DM, but system said you are not accepting messages. Question: Should I not allowed usage tracking access on apps? I thinkng I should disallow. What are your thoughts?
depends on the app, in general I allow for apps like tivimate, rouge apps no
I will allow you direct messages, just need to add you. … added
Should be in settings under “display/picture”…“screen”
And Dangerous you are M’aam! Congrats on your accomplishment. It’s still fun and exciting for me whenever I setup a new box too. Most of the time, afterwards, its immediatley off to the “Backups” Drawer, (or in my case a big covered tote) as I only have so many TV’s! Thats why this time I Positively stated I was going to resist the FOMO and not get a new ONN 4K. But Lo and behold, as fate would have it, My daughter bought me one as a surprise. Its still sitting on the Bench waiting to be “slayed into submission” like all those before it. VICTORY SHALL BE MINE!!!
I am 88 and having hard time finding what u want pls come again
try again
If you look at @PiratePete s answer in the top right corner is a B, click on that and you will see he was answering or talking to someone named Beans, not to you @jst
thx although i can;t confirm can u help
Hi @Reece,
I’m still using my 4k max as my main device. But, I like having the additional storage on this ONN 4k pro. Its going to take a little time before it becomes one of my main box.
I just need to figure out a way to get my gifted IPTV service on this box. Its on my firestick. I searched google and didn’t find any help.
Thanks for the encouragement
Sorry. Help with what?
my onn says it can;t reach the internet
The first thing to try is to shut it off. Then unplug the power cord on it. Wait for say 5 minutes, plug it back in and start it up and see if it connects to your WiFi. Someone else suggested going to the Gear
Gear icon and clicking it, that should take you to settings and then find “Network” and make sure the button beside WiFi is turned on. Troy has a setup guide.
The Back lit remote is a little funky to use the Ring is much lower than a Fire stick so it can be difficult to use without hitting the center Select button or vice or versa. Takes a little getting used to but so far as a F-Sticks only user for 7 years I am still liking this box a lot!
Thank you for the great initial review! I bought mine the other day to use at our off-grid cabin and using NetShare to tether my cell connection, which has been working very well.
I did try to use PdaNet, but the system kept coming up with an Android error whenever I tried to connect to the PdaNet hot spot within the PdaNet app.
So far, I think the box works well. Mne seems to lag a bit and is not as responsive as yours. I will need to check my storage and other things to see if I can speed that up.
One thing I don’t like is not being able to easily get to all of my apps. Having to go through settings and several clicks is a bit of a pain.
So far, everything else seems to be working well on my mine. Oh, and I have the same remote you do. No “Free TV” button or anything else.
Thanks again,
Andy
I believe the remote with the free tv is backlit while the other non free button tv is not.
Set my Onn pro up per TP vid, almost flawlessly. Only issue : tried 2 different flasdrives, both formatted fat32 w/ rufus. ( scan disc ) no bueno. No workee. Help please
try ntfs
Really ??? Okee dokee. I’ll give it a go when i get home. TY
