I can’t get the ONN box to recognize a wifi signal. Why most I hardwire from my router to the Onn box? Am I crazy or what? jb
Did you go into your settings> Network & Internet> WiFi and find the SSID of your network and log into it?
Anyone having issues with audio from apks like syncler beta on the 4k pro onn? I had no issues with playing for example mad max fury road 4k with Dolby Atmos on vudu through my surround sound but on any apk i have for streaming movies the sound will not play the atmos surround at that high quality i get with my shield tv pro. Any advice would be helpful thanks
Miki thabks I went to my wifi settings but found no pllace to log in. I do have a password. p;s help
jb
Find your SSID, which is the name of your WiFi service. It will be on the router. Click on it and then enter your password. SSID stands for “service set identifier” and is your Wi-Fi network name.
On the 4K onn box. Click on the gear on the right hand side go to Wifi Make sure you have this turned on. You should see your Wi-Fi name.
I can not find my ssid
have you tried re-booting the router?
I have but will do again
The second light keeps blinking
Hello All,
I received and setup my ONN 4K Pro today. It took me about 3 hours to setup and download most of my main apps I use daily. I followed TP’s video. It was somewhat easy to configure. My takeaways:
You can rearrange the app on the home page. Happy about that feature.
All apps icons didn’t load to the homepage. Have to go to setting, then apps to see all loaded apps. Fast Task Killer nor VirusTotal Mobile icons loaded to homepage. Wasn’t happy that all app icon didn’t load to homepage.
Don’t like that app permissions will be removed if not used within a month. You must allow permission again. Wish I could turn this feature off.
Overall, I was happy with ease of setup. I love the 32gb storage. I’m still somewhat of a beginner. I loaded: Stremio, SStream, Unlinked, Downloader and added my favorite URLs.
Thanks TP and community, I was able to do this with the knowledge I gained from you all. Lol, I know just enough to be dangerous.
Forget to mention, no backlight on remote.
Thanks PiratePete. I did look in my TV setting. I did not see anywhere to adjust my screen size. But I will look again.
Thanks You
Beans
is anything else connecting to wifi?
Yes I am using it now to talk to you
on the onn box is scanning always avail turned on?
I don’t know I can torn the Onn device on but when I try to go anything else I get the message that I get is I can’t reach the internet right now
have you ever connected the box to the internet via wifi?
That happened to me during my setup. I went back and reselect my wifi and enter password and it connected the 2nd time
Not sure but got past this point before
if you have click on that connection, scroll down and click forget. Go back and re setup
