I was lucky to find the new Walmart Onn 4K Pro Streaming Device through my travels this past week.
Here’s my First Impressions Video.
Buy Onn 4K Pro Streaming Device Online
Not getting any sound on the video. Tried a reset of the phone but still no luck.
I’ll try again later. May be a problem on my end.
Edit: Getting sound on YT and Rumble. Not sure why i cant hear here.
Edit2: for what ever reason it wont play sound in chrome but DDG is fine.
I just picked one up today. It installed easily and it seems super smooth. Apparently you can also put a USB hub with Ethernet on it to get faster Ethernet speeds. Ethernet speeds.
Awesome video Troy! Picked mine up today had a system update out of the Box. Very easy installation and set up and perfect timing with your Video. Love the Shortcut button I mapped it to my IPTV App. And FYI my remote is not backlit but doesn’t matter to me
If you have the 4K Version and thinking of upgrading you are going to love the Pro
enough saying Hey Google, Troy has all my devices waking up looking up chicago weather :crazy_face:
Lol happened to me too! :rofl:
Great video, professional as usual. I may wait until you’re full review before I decide if I’m going to buy one or not. I’m pretty content with the 4K fire Max.
Thank you for your review and looking forward to your next more comprehensive dive into the 4K Pro Onn box. I learn a lot from your videos.
A couple of things that I would like to see in the next review, or someone just answer for me. :slightly_smiling_face: (1) The current Onn box does not have the ability to adjust the screen size. It is just a little bit too big for my Samsung. I need to reduce to about 97%. (2) What adjustments can be made to the default Home Screen? I noticed when you added apps they were showing on the Home Screen. There is also an Apps button on the top. This is the same on the current non Pro box. The previous Onn box (2023) allows the user to add or delete the apps showing on the Home Screen. Then all installed apps are found under the top apps button. I am using the older version on my main tv just for this reason. It keeps it much simpler for the other users.
For some reason i had “Sound Allowed” turned off in the site settings from the TP icon on my phone.
Back to normal.
Thanks for the quick first impressions video, Troy. As always, the best in the business.
Excited to see what kind of impact this box will make in the cord cutting community. Very good specs for $50, and very versatile for an affordable Google TV box. We will be talking about this for a long while, especially once everyone is able to get their hands on it.
Also for those who already have this for apps you cant un-install like netflix you can free up system resources by force stop, uninstall updates and disable.
Great Video Troy !! The box is not to bad at that price point.
Thank you!
Good catch Ron! Let’s see how it handles IPTV
Thanks for the review and years of deep diving into devices and services for us all. Cant wait to see what the future holds and these onn boxes have been affordable and very good alternatives for streaming. :scissors::electric_plug:
I received my new onn 4k pro. Do I need to uninstall any/all data and applications that’s on my older onn version before installing my new 4k pro box?
I’m a little lost, but because I’m not technically smart. Thank you.
Downloaded video (Nice touch!) Much easier to follow for us old guys. (Start/Stop/Backup)
Bravo. Take a bow!
Troy, my remote is not backlit nor does it have the free TV button.
Got a message in Google play that Analiti is no longer available in Google play store.
Maybe you can add to Troypoint toolbox.
Great review love your videos.
He said in the video he will look into Analiti not being available and will add it to the Toolbox if needed.
https://en.uptodown.com/android/search
