I’s not a setting. ONN has 2 different remotes. Some are Backlit some are not. I don’t have the Backlit but could care less.
If the remote you are talking about has the “Free TV” button then it should have the backlight feature. If it wasnt working I guess the update fixed that. I dont remember seeing anyone else on TP complaining about it not working before.
I dont believe its an option but an always active feature. Unless the update changed that.
The original Pro remotes do not have this feature or the Free TV button. Or are you saying this remote has the backlight now working? ![]()
It was probably a firmware update for the remote that brought the backlight back to life.
I’m sure thr topic has been said ad nauseam. Lol. Sideline lurker here but appreciate everyone of you. Especially Troy. I remember back in the day somebody said, “check out this guy and follow him." It all changes from that day.
The Onn 4k Pro. Man O man. Never would I ever believe that something so simple, so user-friendly, could ever just be the problem to the continued accelerated fire stick issues that stacked one on top of the other, month after months. A little bit of grieving seeing my two sticks go but oh well.
Fire sticks should be buried in a time capsule with a note, lesson learned.
LOL. Well said.
I second all but one thing, I don’t hate anybody in the future that much.
Has anyone taken the ONN 4k pro apart and come up with instructions as to physically remove or disable the listening device / microphone?
I’m not a fan of the always listening feature and don’t really trust Google to just not listen all the time despite the hands free feature being turned off in the settings.
You have a button on the side to disable the Microphone.
Oh ok. I have not purchased the device yet and was unaware. Thanks
That is the FIRST thing I did after taking it out of the box. To me, it is just too much like 1984.
So far my 4K works very well, except one issue. When I go in to Troy’s Toolbox the cursor remains in the corners and I can’t download anything. Any idea for a fix? Thanks
Not sure why its happening but did you try to delete and reinstall downloader?
Is the cursor working in other websites?
I’ll try that. Yes it does work in other websites
Lightning hit took out the router, firestick, a TV, etc. I purchased an ONN 4k Pro.
Got it up and running, then thought about the ONN booting problem with flash drive. My wife wouldn’t be able to do it,. Transferred the apps to internal and ejected, and removed the flash drive.
Any install tries to go to external drive. “Force install to external is turned off”.
I’ve rebooted multiple times, turned USB on and off,. I can’t install Analiti! I have to delete apps that are on internal. I don’t get it.
Also, I found that ONN cannot control power for both Insignia TV and ONN sound bar, its one or the other. Tried to remove the ONN, so it would power the TV, and it hangs! Maybe I have a bad remote on top of the other problems. I’ve been badmouithing Amazon, but I sure miss the firstick 4K right now!
Do you have the developer options enabled and in their have “force install to external” enabled?
I have the ONN 4K Pro box and a Vizio TV & Vizio soundbar. What I do is to let the ONN remote control the TV. With my Vizio TV & Soundbar system, when I turn off the TV from the ONN remote), the soundbar turns itself off after a short period of time. You may be able to setup the ONN soundbar so it shuts down after it gets no signal for a short period of time.
As for the flash drive, when you first plugged the flash drive into the ONN box, did you tell it to setup the flash drive as internal or external storage? I suspect you may have set yours up as internal storage. If so, that may be the reason it’s trying to install apps to the external drive (just a guess).
My fire stick is still working good and still fast as ever, I just need to keep from putting too many apps on it. I’m not one to buy a Onn and have to redo all my IPTV favorites I hate that. But when it dies, then I’ll get one.
No, I do not have “force install to eternal” enabled. I turned it off right after I ejected the flash drive.
Flash drive was set up as internal.
It may be a moot point now, as I can’t get the ONN to respond to anything on the remote I’ve even changed batteries twice, reset the ONN, etc.
Is there a way to reset to factory using the reset button on the box?
