Where are you getting that message?
when i input the address to downloader
neither of the vpn dot alternatives work for , i.e. i canât access them through the addresses given
https://max-soft.com/vpndot.asp
Neither works?
not for me, when i input on downloader i get error message
I just entered
vpnprivacydot.(com)
into the downloader, less the brackets, and it took me straight to the apps home page for the download link. Works just fine. It may not work on a âredirectionâ link so entering the url into the address bar is sometimes better as it eliminates a redirection error.
If you type in code â168731â in downloader, it should bring you to vpnmonitordot.com which there is a link to âVPN Monitor Dot App for Firesticksâ.
But you can also try selecting âBrowserâ on the left side in the downloader app and then type in that URL to get to my site.
Then scroll down to the bottom and click on the âDownload FREE - VPN Monitor Dotâ link to install the app.
what downloader are you using,lm using the troy point downloader, could the vpn be blocking it ?
Iâm using the âDownloaderâ app from the Amazon app store.
iâll try it when i get home, thanks
btw, when i input that code to downloader i got the error message
You may want to uninstall and reinstall Downloader from the play store or amazon store. Just so you have a fresh copyâŚthese codes should work.
thanks, iâll try that
nope. Iâm using the downloader that was in the older RAI and can be gotten from the app store.
i just put https://max-soft.com/vpn-dot.apk into downloader and i get 404- file not found
Ya that doesnât work as you know. Put in the following, without the brackets
( https://max-soft.com/ )
and it will take you to the site and a download link.
Yeah, that direct link to the APK is not valid - thatâs why youâre getting the 404. Where did you get that link from?
You need to go to âmax-soft.comâ and then select âVPN Monitor DOTâ webpage link, then scroll down to the bottom and click the download link.
been there tried that, when i enter 168731 it says page not available
for some reason i canât scroll down to the link, can you type the link so i can enter into downloader ?
If it wonât work on Downloader, maybe you can use a browser like Puffin and enter the URL. Maybe that would work better.
