Once you have finished naming your folder you will find it in your “ALL Playlist” folder. Then proceed with copy and move whatever channels you wish to place in your new folder.
I was trying the alternative method you were talking about. Creating a ustvgo folder in tivimate. I don’t see the create folder option anywhere
Please read the previous and look at the pics i posted for you
Got it. I was able to do it now. Thanks
Where can you find local tv networks?
If you can give me your local stations call letters I can see where they can be found for you.
Depends on what local you are looking for and on the device, you intend to stream from.
KCRA in Sacramento is what I’m looking for
Found it (KRCA) on a few sites, but here is a FREE site you can install.
Check your PM for the m3u.
How did you copy the channels from the ustvgo webpage?
Where do you find the EPG for Free2View?
Also the EPG for https://iptv-org.github.io/iptv/countries/us.m3u does has issues. You experiencing the same?
Some of those epgs may no longer be maintained. If you are using Tivimate try updating a few times. When a particular epg is no longer working as it should. Then I would delete it, or at least disable it. I have several free epgs, and a couple from current and previous pd IPTV services. I use all of th for each playlist I have installed.
The F2V m3u I can give you which will have about 11 associated epgs. The m3u is Free and all legal!
Credit Miki for the m3u find. It is a very good m3u and I use it often.
I would appreciate the EPGs and thanks Miki for the m3u find.
I’m very busy at the moment setting up customers with TiViMate and their first foray into IPTV, so if you could please be patient I will put together a list of epg xmls that you need to install, or you can use the search function here to get ones like Stirr, Pluto, Distro etc. Then I’ll PM you with them.
PowerFader has added tons of this stuff as well.
Troy also.
I sent him 16 epg’s in a pm just now.
Holy crap tx PF. I can’t even find a doc creator on my phone. Suppose to have MS Word. Pffffft. Ya if I pay. Have to download an app. Tx for the assist, much appreciated.
Thank you both. Something to start playing with.
Here’s another m3u updated to combine a couple of playlists and epgs.
Combined (440 Channels)
Playlist: https://cutt.ly/DSr95Combined
EPG: https://cutt.ly/DSr95Combinedepg + https://cutt.ly/LocalNowepg
Added January 26, 2022
Combined (Everything All-in-1!)
M3U: https://cutt.ly/DSr95Combined EPG: https://cutt.ly/DSr95Combinedepg
The Combined m3u includes all the m3u’s listed below, except KlowdTV.
DistroTV
M3U: https://cutt.ly/DistroTV EPG: https://cutt.ly/DistroTVepg
WatchyourTV
M3U: https://cutt.ly/WatchyourTV EPG: https://cutt.ly/WatchyourTVepg
Herogo TV
M3U: https://cutt.ly/Herogotvepg EPG: https://cutt.ly/Herogotvepg
Airy.tv
M3U: https://cutt.ly/Airytv EPG: https://cutt.ly/Airytvepg
BumblebeeTV
M3U: https://cutt.ly/BumblebeeTV EPG: https://cutt.ly/BumblebeeTVepg
Veely
M3U: https://cutt.ly/Veely EPG: https://cutt.ly/Veelyepg
Nosey
M3U: https://cutt.ly/Nosey EPG: https://cutt.ly/Noseyepg
Galxy.tv
M3U: https://cutt.ly/Galxytv EPG: https://cutt.ly/Galxytvepg
KlowdTV
M3U: https://cutt.ly/KlowdTV EPG: https://cutt.ly/KlowdTVepg
