TVMob APK installation message
I followed the instructions below…
And got this message…
What should I do?
If you insist on using it then turn off play protect.
I’m using stock android on my UT8 but I think I found the setting…
But now I am a little nervous about installing TVMob. I think I may just pass on it for now.
I stopped using apps like tvmob, livenettv and redbox some time back as it’s easier to get the channels I want with Kodi, TiViMate, OlaTV, and Silk
