Hello, I’ve search for a tivimate review to see if it’s worth the 30-something charge, but I can find a review from Troy or anyone else on YouTube.
Can I use it with an IPTV provider to substitute a stabbing service such as YouTube TV or Hulu with Live TV.
Please direct me to a video or let me know if it will allow series recordings that I’m searching for.
Thanks in advance.
YES. You can use it for a IPTV provider.
It works well.
It tends to (at times) leave a blank space after entering M3U or Xtreme codes when you enter you IPTV. Double check for it if your info “LOOKS” perfect but will not connect…check for it for user name and server and password. It has tripped me up a few times. (blank space is an extra character to the server…)
TiviMate uses M3U or Xtreme code connections.
This means it can use free tv if you have a list.
Miki is the expert on this as well as a few others here. Search for M3U or Xtreme code lists here or on GitHub.
It really is used for paid IPTV.
I use it. I have tried about 5 others that are highly rated.
Other than recordings are .ts format (works with MX Player and not VLC)…it works well.(I wish other formats were available…someone chime in here if they know of another option)
Smarters Pro seems like B+ grade copy. Most Player look alike and have most but not the ‘exactly’ same features.
Hope this helps.
(I ramble…sorry)
It’s 100% worth it. How to Install TiviMate V5.1.0 on Firestick/Android TV (Sep. 2024)
@Jayhawks659 did a very nice video that would probably help you…search for it here…
You need to say what device you are using because recording will need storage.
There is a much newer version for 5.1 is anyone want it.
Hello does any one have the new invite link for cable corners on discord. Can you help please
We only discuss IPTV Services in the locked category that can only be accessed by Patrons.
I would love to give it a look over, thanks
I don’t get it.
I want to because people laughed at it.
Here you go. I protected it for the author. Resellers were editing it and putting their name on it. Dropbox
Thanks for the update @hotwheels
Thanks @hotwheels for sharing, it’s very appreciated, cheers!
This is an enormous help for many with Tivimate Premium!
I’ve been using it for a few years and This year they finally had a few updates. It has a lot of good features and a chat line where you can get quick answers to any problems. I highly recommend it!
If you don’t need or want advanced options and it works for you that’s really all that matters.
Not all IPTV providers will work on Tivimate. Check with you provider first.
What? What IPTV provider doesn’t work in TiViMate? This is a first for me for sure. Oh never mind, can’t name any in this category.
