I have one for sure that won’t work on Tivimate. It has its own platform. The initials are C O TV and is in the unverified IPTV Services in troy point list.
@Miki my IPTV cannot be used on Tivimate either. It has a proprietary app but it doesn’t matter to me. I don’t record and The performance is flawless and $7.99/month for unlimited connections. It’s invite only and for now it appears they are not taking on new subs.
Ya I forgot about those that have proprietary apps, but that has nothing to do with Tivimate or any other IPTV player, that’s the devs choice. A few code changes and the playlist would work. A closed IPTV source is kinda smart these days and I applaud your supplier for not being greedy and understanding this hobby on a different level from some that it’s only about the cash.
Question, has anybody using t i v i m a t e with an IPTV service ever disconnect or disable their playlist for a period of time. And if you did enabled it to the playlist come back on with all the channels except it needs to be updated?
The reason I ask this question, is I want to turn off the playlist on my shield Pro for a period of time without losing it because I loaded my shield Pro with a bunch of recordings schedule but I won’t do not want to record right at the moment. The only way I can stop it if I turn off the playlist otherwise I’d have to either unplug it from the internet which I do not want to do or I would have to delete all all the schedule.
I do it all the time without issues. I do not record so I can’t speak to those sticking. Do a backup before changing to be sure.
