How to Install Duck Streams Stremio Addon with QuickStart
Originally published at: How to Install Duck Streams Stremio Addon with QuickStart
This guide will show you How to Use QuickStart to install Duck Streams Stremio Addon on any device. Duck Streams is a “configuration” of AIOStreams that uses your debrid service/services to serve up HD links wihtout having to install multiple addons. Best of all, setting up and installing Duck Streams is a breeze because of…
Thanks Troy. I have installed it and will give it a go in a bit.
Ok, this add-on is great. I have no idea what it’s done, or how, and I don’t really care, but now my add-ons are loading fast again, and this Duck Addon finds good 4K sources. This is Stremio back to the way it was. Now I’m afraid this will get run over with installs. FYI: I used the advanced setup.:winking_face_with_tongue::face_with_spiral_eyes::flushed_face::smiling_face_with_sunglasses:
Stremio on steroids….with more steroids… POWERHOUSE
Does this override my other addons? Can I uninstall it and will my other addons still be there if I don’t want to keep it?
This isn’t like the bootstrapper. This does not remove or overwrite any of your addons. But if this continues to provide great sources, and has my Debrid accounts integrated into it, then I will remove Comet | Elfhosted and MediaFusion | Elfhosted and maybe even Jacketio, just to get rid of some clutter
Installed along with my BOOTSTRAPPER collection. I never had Torbox added before so now I guess I have both PM + Torbox in my Stremio. Thank you.
Let us know what you think @GraceWilson . I have reconfigured the add-on 3 times now. If you want to get deep into it there is a lot you can do. Now I have to figure out each section and exactly how to set it up and why. :face_with_spiral_eyes::nerd_face:
This great way to get started with AIOStreams. Beware this will install a boatload of addons into the Duck Streams addon. Also by default it won’t install Torbox or Torrentio addons. If you want to change default settings/addons, go to addons/Duck Streams in Stremio on PC or Phone and select the ‘Gear wheel’ next to Uninstall. This will launch the AIOStreams/DuckStreams home page in browser window. Enter your Stremio account password. Then you can setup the filters and remove or add addons. By default the ‘Exclude Uncached’ (Under Filter Settings) is unchecked and it is ok to leave it unchecked as the default Duck Streams settings will only find Cached links. I set the file size to 10GB for Movies/Series/Anime. Files over 10GB may cause buffering IMO. I prefer the ‘Light Google Drive’ setting under ‘Formatter Option’ as it displays essential file information while minimizing clutter and has lightning bolt next to stream to signify its a cached link. Once you have all the settings selected, you want to make sure you click on the ‘Floppy icon’ on left hand side on bottom then ‘Save’.
If you go the expert route there sure is a ton of settings to choose or not choose. :face_with_spiral_eyes: set it up 3 times now and each time I’m learning what the settings do. Lots of new things for sure and some I still don’t quite follow. Working well as another source.
When you going into settings and change things, and you want to keep the changes, you have to click install. That puts a second addon . Isnt there a way to make changes to the addon already installed without adding a second one?
This addon has listed a lot of 4K links. Some of them when I chose it, closed down Stremio. Not sure why that happens.
You do not have to click install. You Just do the save on the AioStreams web site like I mentioned in my post.
Thank you ………..
I’ll play with it later today.
Well, now on Stremio on my computer, the links are causing problems. Either I get audio and no video, or, it shuts down Stremio. I tried another addon and same problem,m…all started when I added Duck. Maybe something in the settings?
Given that duck appears to primarily use Torrentio, Comet and Mediafusion, why should we expect anything but problems with it?
That’s why you need to tweak it and remove addons that are problematic. Also play around with filters that Aiostreams offers. Duck Streams is an easy way to get Aiostreams installed. The only addons I use are Torbox, Debridio and StremThruTorz.
What is and how to get Real-Debrid API key and Premiumize API key? Are these the codes we are asked to input when authorizing them in an add-on?
Well mostly because experienced users have given it a go and two thumbs up and I have no idea what scrapers they use but damn they find a ton of 4K, HDR and DV, where the reg torrentio wit debrid services don’t. No clue why that is it just is and I don’t question it.
Do you need a Debrid to use this.
I have been using it for a while, I rarely used Stremio, opting for Weyd and Debrid Stream, apparently I had to much set up on it and it wasn’t user friendly to me. Once I started using Ducks set up, I got rid of everything else except some things in Debridio, I use it with RD, TB and Debridio, and I also take the URL of the set up and put it in the Scrapers section of STRMR.
He has many guides and tools on his site. He also puts a lot of work into his stuff, always changing things some and trying to make them better.
Also I use this to re-order things in Stremio.
