Startup of Kodi Builds
When it comes to starting a build up, in this case diggz, how long must I wait for everything to load everytime? Also seems like everything I open and try to use…always comes up “error” and shows me blank screen, or a constant “working” popup
All keep seeing is how good these kodi builds are, but based on just my experience…its not worth it!!
Wth am doing wrong??! Hah
On a 4k FS…few hundred DL speed…
I don’t recommend builds for a stick. They don’t have enough ram or memory for them. There a few others here that will disagree. You may want to go with Kodi with just two addons like The Crew and Mad Titan. They will give you most of what you need. Iptv, movies and shows. Just my opinion.
Builds are not recommended for firesticks as mentioned above.
Just use a single addon
All sticks or just the 4k one I have?
Those 2 addons would give me; tv…movies…24/7…sports and such?
I go about putting single addons same way put builds on?
They have quite a bit tv especially Mad Titan. It has live tv shows and sports. If you have special shows not found you may need a separate iptv. You will just need to try them out.
Hey thank you, sir!
I did, and have, put them on in place of the full build.
Will read those posts before asking next question I have.
Edit…just read. Question…
I have enabled AD on The Crew, but when go to pick a tv shows episode…it will showbme all the links scraped, paid and free, ut when to actually pick one of those, it says " add to queue" or dowbloading. Is this normal?
You don’t want to download because of your stick storage limitations. Click on one that fits your need to watch. Here is a guide made by jayhawk to change settings to speedup Kodi.
Only option its giving me is to “cancel” the download…then it asks me if I want it to download in the backround…then when hit “no” it says “one or more links cant be found” , and nothing plays… understand what your saying…download bad haha
Thanks for help and hope not wasting time.
Not wasting time, we will get you going. I have been getting this lately myself, mostly on older shows. They are un-streamable links. Move on to another link.
Here is a good guide made by Jayhaws for speeding up Kodi:
See I thought the AD links that it was doing it on…wasnt supposed to do that? It found the paid links and that that meant there were playable links? Daid show It wad happening on, wasnt nearly that old…2 years mebbe…
Thought thats how it worked haha
And thank you all help is ppreciated
This is something that just started, for me anyway. Maybe someone else will chime in letting us know why that happens with debrid links.
Heeeey alright…so its not just me!
Ok…I guess I hang round and look for solutions and/or updates then?
PM me the name of the show and will check if I get any RD working links.
Will do…
…as soon as figure out how lol
Just click on my brain on fire profile picture.
Says Your profile is hidden, nothing else. :sweat_smile:
Don’t know what is going on. I have allow users to message me.
I tried a few from each season and was able to play. I do have Real Debrid where you have All Debrid. That may be the difference I am not sure.
RD superior to AD when comes to certain apps? Including these ones?
