Anybody getting mac codes to work in stalker portal in Sparkle plus ?
Yes. Working for me.
Can you explain what that us?
I set it up just like the tutorial says and the sparkle app on my android device accepts my email and password but when I go into the sparkle app and go into connect shared plus account and enter the same email and password it always says email or password incorrect so I donāt know what is going on? I even sent email to the creator and heās tried it on his end and it doesnāt work for him either
Well thereās your answer. If it doesnāt work for the dev then nothing we can do. Hopefully he sorts it out for ya.
I have Sparkle Plus an have 3 mac codes installed but I canāt figure out how to chance from a code to another . I have looked everywhere . Can I get some help please ?
I also figured this out . Theirās a few different adjustments after you add the mac that I wasnāt doing . I think I got it now .
It itās littled different once you get the hang of it not bad.
What iptv services you use for all them channels and movies
I have 4 pd providers and about a half dozen freebie m3us.
Lifetime Sparkle IPTV player going up to $19.99 (from $15.99) after Jan 1. Just a heads up, posted on Discord.
yeah, I saw that this morning. Itās still worth it to have in your arsenal of players.
Please let us know if you get it. I got Sparkle as I heard the recording feature was better than Tivimate. However, while the rewind, fast forward, and pause are there, the red record button is not so I can not record. Iāve asked for help but no one has responded to this issue.
I decided to check this out, maybe as a replacement for tivimate. It appeared that you could not use the epg without paying for premium, so i abandoned it.
Sorry.
Hi hi has anybody found a backup or restore on the sparkle TV app
Settings ā Sources ā Setup ā Export/Restore
https://www.reddit.com/r/SparklePlayer/comments/13uzdq4/how_to_do_a_backup_and_restore/
Thank you
Well, as usual, I am late to the party but, you have peaked my interest. I am going to tryout Sparkle just because I can. I love this hobby.
