For those having issues with puffin etc on android(me)…I grabbed a copy of silk from HERE…if you read down the list I grabbed 96.2.18.4.175.30 and side loaded it and it works great, built in cursor and all. ![]()
And as it’s cloud based it’s footprint is small. It’s optimized for Firesticks and plays live stream perfectly. I use it every day to access sports and to test sites that offer free movies and series as well.
Thanks @TXRon. That’s the best update info I’ve seen for Silk. Great resource.
How well does it handle downloads? I have firefox right now, but is a pain in the butt! Can’t stand using Downloader because of that bs little circle used as a pointer. Do you think Silk is better than Puffin?
I use… BRAVE… it is excellent… Best browser for privacy…
I have that on my laptop. Do you have a link for use on a nvidia device?
My only choice also.![]()
