I followed Troy’s video and did successfully install Seren along with Real-Debrid. I got to the step to show the links for Night of the Living Dead, but I see a message on my tv screen that reads: Seren It seems you have no providers installed. Are you sure you wish to continue. Yes or No.
I clicked yes, but no links show up. What needs to be done to view the links? Thanks
Thanks Miki. I have it installed properly now. If you could help me with a question? I have chosen a tv program, but do not know how to add it to a library, so I can access it without having to do a search all over again. Thanks.
Sorry my friend, I’m not the guy to ask about using Kodi. I had it 3yrs years ago when it was good but won’t ever go back to it now. I’m sure Dracoo or Powerfader will be able to help.
Hi @hammer
Don’t forget to add scrapers
Provider Tools> Manage Provider Packages> Install Package> Web Location> http://bit.ly/a4kScrapers > Install>ok
Then hit your back button a few times to go back to Kodi Home Screen and test it out using real-debrid
Good luck
All works fine. Just do not know how to add a tv program or movie to favorites, or any other place to store it. I find that I have to do a search all over again.
@hammer
If you want to add a TV Show to favorites, just long press the select button on your remote and then scroll down to favorites and click.
Now when you go back to Kodi Home Screen, scroll down to favorites , it should be there.
Will this work with Seren? Will have to wait until tomorrow to try. Thanks for the tip.
press and hold the ok button on the progamme and add to favorites you can then find it at the bottom left of your main menu screen just press the star
regards
I’m having the same issue. When I put the web address for the scrapers section (http://bit.ly/a4kScrapers) and hit ok nothing happens. I don’t get a conformation box. No install or anything. I’ve been having this problem for months. Can anyone help?
Hi @Bra
Welcome to the community. Hope you find it useful and helpful.
Sorry you’re having problems for a while.
I use this app daily, and it works great once it’s set up.
In your situation, go back and check to ensure that app was installed correctly.
I apologize if I come across disrespectful, not my intention, sometimes it easy to incorrectly spell something, or miss a step. This tutorial should help.
Come back here if you are having any further problems or have any more questions.
Good luck!
Remember it is a capital S for scrapers in the web address.
Thank you very much for this. I had same issue and fairly new to Kodi. Just learning the in’s and out’s. Very cool
I’ve followed the step by step instructions for Seren including the uploading of the A4k scrapers and even backtracked to insure I was installing everything correctly. I am still getting the drop box message
“No Playable Sources Found For Item”. I’m at my wits end.
Any advice would be greatly appreciated.
Hi jericho777
Sorry you’re having so much trouble.
So, I want understand you completely, you have installed everything completely and correctly, including installing the A4kScrapers (ensuring the S in Scrapers is capitalized).
Do you use Real-Debrid?
If so, I’d ensure your Real-Debrid account hasn’t expired.
Reply back to me and let me know if this fixed your issue. If it didn’t, let me know that too, so that I can do more troubleshooting.
Thanks for reaching out.
Thank you Sbrown for responding.
I did find after trouble shooting that the Torrents weren’t enabled in the Seren settings.
After enabling them, everything worked fine until after the second program I played.
Then the Seren Error Log kept popping up every 10 or 15 seconds during the second program I played. I tried trouble shooting for the cause of it and ended up uninstalling
Seren and are going to attempt to reload the addon again.
My Real-Debrid is good to June 2024.
Gods speed and thank you.
Hi Sbrown
Did an uninstall & reinstalled per Troy’s instructions and everything is working great. As of now during the first program played, I am getting no `Seren Error Logs. I’ll know more after playing the second program.
Thank you and have a Marvelous Monday.
