Problem solved. Thanks to all who responded.
Hi @jericho777
Glad you are up and running.
Please don’t hesitate to reach out any time for any assistance you may need or any questions you have, I’m happy to be of service.
Have a blessed day.
Thank you.
Everything is up and doing well. The uninstall and reinstall did the trick. That or I missed something hahahaha…
Really appreciate your time and help.
Hey,
Wondered if anyone could help. Same problem with adding a4kScrapers. The link is typed exactly as it should be however when I press enter, it just sticks on a page with a spinning cog. Won’t let you exit etc. Have done the uninstall and tried again but the exact same thing. I’ve now tried it via my firestick rather than the t95 and I’m still having the same problem.
Just to add, real debrid is all up to date.
It’s driving me bonkers. Please help.
If using a VPN maybe try to disable that while doing that step and see if that helps. Or, if you aren’t using a VPN maybe your ISP is blocking access to that link.
