I have been having trouble with Real-debrid and buffering. I got the new Fire stick and the performance seems to be better than the old stick but the buffering issue is still present.
@Fiji1961
I appreciate using the forum and search but let’s try to not hijack an existing topic with a slightly different problems. Creates a cluster.
Streaming apps and buffering
Hello! Alot of you mention buffering and having issues with it. I’m going to break it down to help you. Buffering resolutions always stem from troubleshooting. This will more or less be what to do when I encounter buffering.
Always check your down speeds, it could be your isp is having server congestion or high nose. Peak times is when this becomes a issues. Sometimes it’s just your isp.
Fire stick buffering.
Kodi buffering
Follow those links, they have pretty …
This step-by-step guide will show you How to Stop Buffering on Firestick in 2022. You can stop buffering on Firestick by increasing network speed, using an ethernet connection, updating software, using a fast VPN, and many other solutions found in...
Est. reading time: 12 minutes
system
Closed
December 29, 2021, 9:42pm
5
This topic was automatically closed after 6 days. New replies are no longer allowed.
