Problems with Kodi add-ons
I’m downloading add-ons on kodi and there are no dependices when I’m installing the add-ons which means there are no streams that we can get. Is there anyone else having this trouble? Have a fire cube and using premiumizer for debrid since real debrid doesn’t work anymore.
I have ZERO issues, no. I’m no expert and don’t know exactly what a “dependency” is, I do know what a “Depends” is though, :grinning_face:. I download the repository, unzip, install the add on, add PM or TB and all works perfectly.
Which addon and what dependency does it say is missing :thinking:
When I go to install the add-ons a box comes up which shows the dependices and it shows 0 on everything in the box which you’re supposed to hit the continue button. When there’s no dependices there’s no reason to continue. It also has the scrappers that it’s supposed to use in the box. I took a picture of the box but I don’t know how to put it on here. New to putting things on here
Crew, seren, umbrella
Could it be that my firecube isn’t allowing me to download anything anymore?
That is a very distinct possibility. There are quite a few threads, here on the Insider discussing the current state of the Amazon Fire devices.
Yeah I’ve been reading about that. I’ve set it up so it wouldn’t update 8.0 whatever version. Been working great until I went and reloaded some add-ons now it went to crap!!!
This is strange. Not sure why you are doing anything with the dependencies. Been using KODI for 10+ years and when I install an addon I’ve never had to do anything or see anything regarding a dependency.
There’s a box that comes up when I install the add-ons that say zero dependices.
Actually if I remember correctly it says the dependices haven’t been satisfied
Could be for some reason whatever dependencies you need aren’t being reachable, possible maintenance which means it might work later. If you knew what dependencies they were there may be another way to install them from somewhere else.
:laughing:
Not sure how I would do that. I’m the person that needs to watch a video on how to do much with tech stuff!!!
Could always try a different addon, I know these are working good. :backhand_index_pointing_down::backhand_index_pointing_down::backhand_index_pointing_down: What Kodi version are you using? Should be 21.3
Actually I installed a build now and it has pov and red-light add-ons and those are the only ones that I can get to work. Thanks
And I do have 21.3 kodi version.
@Ram0064 Red Light gets non stop updates so you should be in good shape with those 2.
Thank you!
