I use PM, is there anything NEW I need to toggle on or toggle off?
In the 11 sources, I have piratebay, torrentio, aiostreams, comet and media fusion toggled ON. What do you utilize?
I’ve seen links pull from the “torrentdownload” source on other apps. Do I want that toggled ON here? Does that source really “download” or is that just its name?
Nothing needed to be changed if you are a premiumize user.
I recommend turning on torrentdownload and torrentsdb. They are providing some quality sources as well.
If there is a source from any of these options it will either stream immediately because it is a cached source or it will be downloaded to your premiumize cloud and be available once it is completed.
I did notice the changes yesterday to the POV addon but I am still getting crowd sourced cache results.
Kodifitzwell did make a comment on Reddit and said they have changed the addon to a different method for RD and AD so that’s why the settings have changed. Which is more simplified imo.
Still one of the best add-ons imo and thanks to the dev who works on it for free as do most of the third party Kodi add-on developers.
I have Fen light on my Kodi box . I get an update box popping up everyday . Every time I update it to the newest update it will not update . I have tried many times an it just stays at the same date . Do I need to reinstall the addon or is their a solution to this problem ?
I installed the new update but when I check the update It’s giving me the old update version 2.0.07 . I did everything right . Dose the new update number show up in the addon after you update it ?
Check that the GitHub repo address is correct because if not the add-on will not update to the new fork and will still use the Umbrella repo with Fen light 2.0.07
After completing the process I click back an click update I get a box saying I have successfully updated to 2.1.31 . But when I long press on the addon an check the update it is still saying 2.0.07 . When I turn kodi off an back on I again get the update box telling me o update from 2.0.07 to 2.1.31 . So I don’t no what I’m doing wrong .
It is the original version . I’m trying to convert it to Fen Light AM by using Troypoint’s instruction so I don’t have to start over . Should I just start from scratch ?
Is anyone else having problem with POV Kodi addon not recognizing or playing from Real-Debrid or premiumize?
I’m using onn 4k pro android tv box with kodi 21.3. I have real debrid installed along with premiumize me. It shows I have real debrid but when I go to check my rd account status it won’t even open the information status… and the rd cloud and history are totally blank. Then I check my premiumize account status and it opens and shows I’m paid thru April 2026. When I go to the rd website online it shows my account is active and I still have almost 3 months remaining.
When trying to view a video and that shows rd cached, or upload to cloud it searches for the different ones available and shows several available ones to choose from and download from, but keeps saying no sites to download from. Then I check / browse the rd menu site they show as available, but it says no url exists or can’t find url site.
So far This only happens with POV. So if anyone can tell me if POV Kodi addon is still working I’d appreciate it
Hi Patachou understood. Are you using a Build or individual Addons? I wanted to see if you have tried Reauthorizing RD in the POV Addon? If so and you are still having issues hopefully some one else familiar with POV can assist
[/quote]
I am using an individual Addon for POV. I have tried reauthorizing RD in the Addon but it won’t allow me to open the authentication/reauthorization from the setup menu like I can with premiumize me or even add coco scrapers
