Can’t add cocoscrapers, it already has a scraper. Not sure why there’s no where to authorize RD, it’s showing on mine.![]()
Hi @PapaS it shows on mine too, but won’t let me open to authorize or (reauthorize). I try to open it on the menu but nothing happens… it’s like a dead menu option. Trying to click on it and it just acts like it doesn’t exist.
In that case I would uninstall and try to re-install. That’s a weird one.![]()
That’s what I was afraid of @PapaS ![]()
I don’t know why it doesn’t appear in the main settings menu, but the only place I can find to authorize or reauthorize various services is in the “My Services” section of the settings menu initially.
I stress, this this is “My Services” section of the initial settings menu. You’ll find it directly under the “Settings POV” option.
In this area you should be able to reauthorize your Real Debrid account if necessary.
Hey maybe you can help onnprobox pov tmdb Airing today is coming up empty,but tmdb movies fine. Also using developers API key ? For tmdb
