Onn Android box...and Mouse Toggle
I set the Onn Android Box up as per Troy’s video which included Wolf Launcher and Mouse Toggle. Wolf locked everything up. Couldn’t use anything. Had to factory reset. I followed the instructions, again, but did not install Wolf Launcher or Mouse Toggle. I would like to use Mouse Toggle. Can I install that separately without Wolf? I only use a few apps. Mostly to watch BBC series. So, my question is…can I install Toggle Mouse as a separate app?
It is a stand alone app.
Thank you.
I was trying to add my camera app to an Onn streaming device, and I could not get it to click on some of the buttons. So I downloaded the mouse toggle MATVT. After following along with Troy’s video, should have worked, right? Well, sort of. I can get it to move, no problem, but it will not click. After an hour, I decided to give up (slow learner) and looked for something on the forum. I came across a thread about a mini wireless keyboard. Can I use something like that on a 4K Onn Streaming Device? And if the answer is yes, what do I plug the receiver thing in to?
Thank you guys in advance
MsParedes
I am sure someone with more technical knowledge than I have can help you more. If the receiver is a USB, there is only one USB slot on the Onn which is plugged into the TV. I am thinking that, perhaps, if it is possible to get USB extension cable with two USB slots, you might be able to do that. The USB end would plug into the Onn and there would be two USB slots. I’m not sure is that is possible but, if it were me, I would try it.
Thank you. I hope someone has a solution.
Does anyone know why the mouse will not click and if so how do I fix that?
I have installed mouse toggle. I have assigned a Boss key. I get the d-pad & mouse mode to come on with pointer BUT when I try to click on something - I GET NOTHING!
Can anyone give me a hand & help me out with this? Pretty Please?
Try all over and assign a new boss key.
Follow this set of instructions by TROY.
Install Toggle mouse for Android.
I just tested it on my ONN box.Works fine.
( I normally use a IpazzPort Keyboard but even the $5 keyboard from 5 Below discount store works almost as good.)
Hi I use the UGREEN USB 3.0 Hub Ethernet Adapter, and an OTG Cable with my Onn streaming stick. This allows me to use an actual real click mouse. All on Amazon. You can also look up instructions on how to use it on this platform. The app just doesn’t work with Onn.
I just need a mouse at times. I will try tomorrow - thanks
There is no USB port on the original ONN box. I also have the 2024 ONN 4K with a USB port but the port no longer works. Only 2 months old!! Thought I would try the Mouse Toggle.
Unsure how I would hook all that up.
Here’s a Troypoint video. This works with the ONN 4K Streaming box https://m.youtube.com/watch?v=Z4IWu952aSU
Try developers options there’s something in there which controls animation you might have put it too low because I know Troy was explaining that you can’t he had it originally at zero and it that’s what stopped the nomination stop the mouse working so that’s why he was the point five instead of one try put it back up the one to try it again and not affect I just bought from Amazon a USB has four slots for the USB micro and I got it I’ll see if I get the name I got to pull right still have the because I’ve tried so many of these and they what they do is they put fire stick into a loop it must cut down the power that it’s supplying for the fire stick that’s why I go into a loop and I just brought two of them with my Android box and one for the fire stick Max and it worked awesome it’s working perfect so good luck I just want to make sure you understood that in developers options there’s a emanation it’s three of them
Thanks one & all - Mouse toggle is now working!!
I’ve found this app works much better than Mouse toggle on my 4k Max.
Mouse control using your phone as well as a keyboard.
Android TV ADB Mouse Keyboard - Apps on Google Play
I am very new at this but followed Troy’s video but have run into two problems.
  1. When I try to download the Sideloader Launcher, I get a message that is is not compatible with my TV. (Vizio E43 C2) I can’t get any fartherl
  2. I did download the MATVT - Mouse for Android TV. When I try to enable “Mouse Services” it will not remain enabled. The blue dot lights for a split second then it goes back to disabled.
I would be very grateful for any suggestions that anyone has.
Thanks
@RBooks370
Are you loading this on your TV or a streaming box (if box, which one)?
Very sorry I forgot that. I am loading it onto a Onn Pro box attached to Vizio E43 C2 TV.
