just installed ⦠working gine
Downloaded the NOROFIRE app and now Iāve got my sportsfire back and works just as well as before.
mickg
Just installed norofire app and installed streamfire and its working now. I did have Google play services and Google carrier services installed and removed them. My sportsfire only had issues for a few of days when when streamfire went down.
I updated my sportsfire app in unlinked to the new version and worked just fine after the update. Thank you to everyone who helped and shared their information.
Unlinked has been pretty reliable for me and I like that they have some of the older versions of some apps. I usually keep a copy of the apks in a USB flash drive before they start doing all the updates and coming out with new versions of the apps. And when something like this happens I just uninstall and reinstall an older version of the app and just ignore the update pop-ups until it forces me to update it or a reliable version finally comes out or if something better is now available. Unfortunately it didnt work this time for streamfire, but I didnt think to remove the Google play services and Google carrier services which probably would have solved my problem a while ago.
Thanks again for everyoneās help and advice.
What might not work for you might help someone else, so please keep sharing.
@jc7896
to the Insider!
I just updated to sportsfire 3.10 and it no longer works on my tablet. It used to work fine with AVT launcher even before Norofire and 3.0 worked after Norofire but 3.10 seems to load and then crashes or just quits sometimes with the error āsportsfire keeps stopping.ā Streamfire loads still but the streams are not playing well or at all. I havenāt played too much with it yet. Unfortunately no way in Norofire to load older versions.
I had similar problems I deleted everything inc norofire and reinstalled everything all ok now
How did you get sporsfire app
Just scroll up all details. And downloader codes are hereā![]()
Hello, What is the downlaoder code for Sportzx pls?
Try these 5628419 or5699355
Iāve been consistently experiencing a sound/image sync problem on just one channel on Sportsfire lately.
Is it happening to anyone else or is it a glitch in my SF version?
Thanks!
edit: Iām guessing it has to do with how SF is forwarding this particular channel stream. Wish they had a feedback link.
All fine here
Hi what boxes works outside the us.
I was missing UKT. the app said I have it, but was nowhere to be found. I assumed projectivy had a update because I had to enter everything again. I was trying to get accessibility turn on. I remembered something Troy said. So, I deleted pivy and reloaded from google play store . I found UKT and tapping āmore infoā I was able to delete and reinstall. that solved the problem. donāt know why the other problem existed, just dealt with it.
They have a Telegram page. Sportsfireapp
They may help you there.
Help please, I had installed noroofire and had both stream fire and Sports Fire working just fine but stream fire had one channel with a glitching issue so I decided to try and fix it by updating or uninstalling and reinstalling and now I cannot get norofire to install either one. I am using an on 4K streaming device. Play protect is off and permissions were granted. I also tried without my VPN on to no avail. TCL TV
What code did you use 7446077 is the latest and also clear downloader cache
As if April 11th thisnis the newest info for Norofire and the apps
We have released the new version of Norofire 1.1
Please follow the instructions below to update:
Do not use the IN-APP INSTALL BUTTON to update
Uninstall the current Norofire 1.0 version from your device
Use the downloader code: 3255605, or visit https://norofire.app to get the download code for Norofire 1.1
Install the new version
This update includes several major bug fixes.
Please note that Norofire 1.0 will EXPIRE and will no longer be usable in the coming days.
If you face any issues, please contact us at help@norofire.app
