Many thanks worked like a dream.
Got my code and installed it and followed the instructions and got them both working fine so far on my Fire Cube.
Both are working like a charm,with no buffering whatsoever!!!
Just ran the installer with the Downloader code 6185176 (THANKS TO @WAINGRO !). Everything seems to be working perfectly.
P.S. - Sorry for the late edit. Everything is working fine on Onn4K Plus and BuzzTV6. I cleared cache and restarted before trying, so maybe that will help.
I have a Firecube, I went to www.noofire.app on my computer where it gave downloader code 3255605. I used it on Firecube and was happily surprised. Working great.
Is thete a way to get EPG which seems to be gone from streamfire?
Sportsfire used to work great for me, until it got blocked. Then every channel you clicked on, would never load. It would just say āTrying to reconnectā¦ā, but it never did. This whole time Streamfire continued working just fine for me. I just removed both apps, and followed the instructions for the Norofire app installation. All 3 apps (Norofire, Sportsfire, & Streamfire) installed without issue, and work when launched. The new Streamfire works as it did before, which is awesome. But the new Sportsfire acts just like the old version, where any channel selected yields, āTrying to reconnectā¦ā Bummer!
Download 3255605 and follow instructions
Yes, it worked. Yes, it works.
Mine is working on sportsfire have some buffering on some sportsnet channels.but have slow internet. Useing netgard with built in vpn
I agree. Sophos intercept flags both apps as malware. Running Onn Pro Android box.
Hi, i canāt install any apk atm. Either through downloader or when using clone app. I either get a notification on screen saying I need permission for APKs or ,after clicking install, it just comes up with the ādoneā button (no āopenā) & no sign of the app
If you have google play protect turn it off
This was posted on their Telegram page on April 11th.
See if this helps and turning off Play Protect as suggested by @pirate77
We have released the new version of Norofire 1.1
Please follow the instructions below to update:
Do not use the IN-APP INSTALL BUTTON to update
Uninstall the current Norofire 1.0 version from your device
Use the downloader code: 3255605, or visit https://norofire.app to get the download code for Norofire 1.1
Install the new version
This update includes several major bug fixes.
Please note that Norofire 1.0 will EXPIRE and will no longer be usable in the coming days.
If you face any issues, please contact us at help@norofire.app
Donāt have that option .itās a fire tv.
Iāve been sideloading on firestick for years with no problems .
The ability to install apkās has just gone overnight .
- no point trying the suggestion below(altho I did) as it is saying the same method Iāve been using
Is there a download code for sports fire?
@jmangat, no promises but here is a good place to startā¦
Just scroll up on here all info on this post
Just installed Norofire 1.1 used code 3255605 using Firestick 4k Max both apps are working good thanks for the posts Take Care All !!!
Just to update. Deleted and reinstalled Downloader. Turned off VPN (PIA), and Norofire installed fine.
