My $1.50 Alibaba iptv has died
Which reseller have you signed up with? Search for “world IPTV service subscription “ gives masses of hits, including set top boxes. Maybe someone can share a link?
If you you use link that Troy originally provided, the page that launches shows ”this product is no longer available”. If there is another way to get to it, I don’t know of it.
Amberbaby on mine is still working fine.
I’ve sent Amberbaby two messages and have not received a response. Perhaps I’m not doing it correctly. Anyone know if she’s still active?
Have you tried her on Telegram?
this is her site
Company Overview - Shenzhen Zhongcheng Electronic Technology Co., Ltd. (alibaba.com)
Thank you all. Great help as usual.
Sorry for a staggeringly late reply. But ‘yup’ “really”.
It’s VPN location sensitive. Try Surfshark: Canada, Montreal. Seriously, it’s been flawless. And ‘no’ I’m not in China …or related.
Use that VPN location - then try each of the server addresses that he provides.
Thanks for the reply. I don’t use a VPN and gave up on that service several months ago. It was never going to be more than a backup anyway to my main service and the price was so cheap I really didn’t care if it works or not.
Nope. Not working. Have 2 links both dead! Total ripoff!
Tried your suggestion. Dead. I get nothing
I only had it as a backup and it seems to be having some issues at times. These Chinese iptv should always be viewed as never your main service because of their issues. For $32 a year if it stop tomorrow I’m not going to too upset
Which service are you talking about?
You should contact provider to confirm the service username, password and url.
Double check the correct info has been entered - a little mistake will return error message.
If the service loads but you see black screen - you need vpn and switch to a different area or country
Apparently they had a problem on there end and I never got any information from AmberBaby. I finally got in touch with her and she issued me a new password which resolved the issue.
Most of the Chinese Services appear to be sourced from a chap named ‘Michael’. I’ll come back later and find the name. It’s his service that’s the source. He replies to issues rapidly and has been very helpful. He’s not a scam merchant.
The issues appear to stem from the choice of VPN. I find that Montreal Canada solved most of the occasional time-outs.
HOWEVER, I agree that these Chinese sources should only be a backup for a good supplier. I use “Darkside.Plus”. Don’t use the other ‘Darkside’ source. Find the ‘plus’ one. I’ve used it for 6 years without issues.
Best of luck.
Found it: I am Michael Wu,The price for renewals and new subscriptions remains at $18
So is it still working , also I dont use a VPN do i need to use a VPN to use thier services
Yes I have her Strong 8K service as a backup and do not use a VPN. The service is working great
Yes, it’s still working. I get a fair amount of buffering (despite the fact that I have 1 gig internet service). I am using a VPN and switch servers when the buffering gets a bit much which helps. I wouldn’t use any of these IPTV services without a VPN. Just my opinion.
1000001382
