My $1.50 Alibaba iptv has died
I bought a 12 subscription after seeing it on Troypoint. £15. They sent me 4 codes to test before i bought. I used 2 of them straight away, for 2 TV’s.
After a while i tried to install it on my tablet, but they wouldn’t work. I “chatted” to C.S, told them my problem and learnt these codes are only active for a limited time. However, as i had 11 months left they kindly sent ànother code for my tablet.
I use iptv smarters on 2 TV’s and i cast when using the tablet.This is my first time replying, so i hope it helps.
Been using mine all morning without a single hiccup.
I did a reboot, took it off and put it back on. It’s been working fine since, no buffering and got the guide back.
I just had to change my VPN location like others. Service has been solid. Michael Wu is my contact, he is very quick to respond if I have questions.
My one packed up as well. I reached out to Michael Wu, the seller, and he promised a refund
I’ve had very few issues with this service. I do at times have to turn off vpn, go into tivimate to connect to service then back out to turn vpn back on and seems to correct connection issue. This happened last night with both my alibaba services.
Mine is still up.
Mine has been working. I don’t like ipsmarters. I use buzz box 5 so I enter the information the same way.
About a week ago it didn’t work for a few hours but it’s been fine
You never know it might come back up in a few days. Me personally I wouldn’t buy IPTV from China but that’s just my two cents.
It is confusing which link to buy the IPTV from on alibaba can someone reply to me which seller or a link to purchase from? Thanks in advance!
While there are plenty to choose from, look for price and category that suits your need and request a 24 hour free trial is my best advice.
Michael Wu is the best supplier.
He’s
Shenzeng Yisheng Source Technology
Those that have issues with the dreaded spinning arrow just contact Michael via Alibaba. An excellent provider.
Ehhh. I bought his $18 service when Troy promoted him when he was on Alibaba fully expecting it to not be good and nothing but a backup at that price. That’s exactly what happened. If the service can’t be flawless on NFL Sunday’s with a current EPG (Not from week’s ago) it goes into the trash can for me
I have been running it about 4 months I have had no real problems with it I use surf shark vpn the guide is as good as most others worth every penny 18.00 bucks a year great budget service. I do keep backups for hiccups but all services I use have them even the more expensive ones.
My guide has issues once in awhile and shows a lot of no info. I get more buffering from Alibaba than with my regular one. If I can renew in Nov at the same cheap price I probably will just to have abackup but if it goes up in price probably not. I tried one that Troy recommended for a free 36 hr trial and I didn’t see much difference, but at a higher price. So in my opinion the jury is still out on services. All I want is a fairly reliable service, which we know none are perfect
My Alibaba iptv still works great
Still working for two providers from Alibaba. Am now using EPG.best to give seven days. Mapping it all was painful but got the hang of it under a SPARKLE app.
My Alibaba still works just fine
Try World IPTV subscription
