My $1.50 Alibaba iptv has died
My $1.50 Alibaba iptv service, which was a very popular discussion a few weeks back, has died this morning. Anyone else?
Mine as well, will not update. Could it be the IPTV Smarters Pro Player, I only ask because it comes up as webpage not available under the troypoint tool box section when clicking download on it.
Mine has died also. I’ve been working all day Sunday trying to get it up. Thought it was my internet, but it isn’t.
When I originally signed up I was sent 4 links. I set up three of them in smarters. None of those are now working. So I just set up a new user using the 4th link and it works. So I’m thinking I need to delete the other 3 and set them up again, refreshing the login.
I did what you said, used the 4th link, (the other 3 don’t work) and it’s working again, thanks for the suggestion!
The person running this service started a thread and advise was to use VPN with Alibaba service, try changing VPN location
Screenshot from 2024-01-08 20-55-26
I always use a vpn (ss) and tried several location servers. Still problems. It’s appears to me that the service’s three puott links are down.
I’ll try again.
Did you contact the seller on alibaba? when mine went out i contacted the seller by pm on alibaba and the sent me a new link and refreshed it for a year
AmberBaby!!! :rofl:
I read this thread and tried my connection and it wasn’t working. Logged into a different country and it all came back. Very strange but happy now
Had same issue. I wound up changing vpn location that worked before, had to be moved to another country.
MikeN just responded before seeing your post. That is what I did. Was using locations in Canada witch worked before. Switched to USA and perfect again.
Mine still works very good
I’ve been using Alibaba.com since November, hasn’t gone down yet
How do you order this service? I go to the website and there’s a dozen different IPTV providers listed. Very confusing!
From what I can tell, the service that is the subject of this thread is not available for new sign ups. Troy’s initial sign up link no longer works.
Mine is working well using Tivimate.
However I am having some issues with SmartersPro
Try using Sparkle tv player…i bought lifetime and it’s almost as good as tivimate and buffers alot less
When TP posted the topic. 65K+ Insider membership SLAMMED Alibaba and they couldn’t handle the load.
Wu should have put a cap on new subs to better serve all his subs.
I was using when i first got the service and i set my VPN for LA USA and it worked great bit lately it didn’t so i played around and found the one that works for me in California, switched to Mexico.
