Kodi guides and info
I just tried POV, authorized Real Debrid, per TP’s instructions and no links are available.
So what else do I need to do?
Umbrella and The Crew are finding links using the same searches.
You need to go into the settings area and go to the second my services tab.
Turn on the torrent+, MF+, and comet+ options.
Also select real debrid underneath each selection. This will show cached material.
This should have the addon searching correctly if you are using real debrid.
Thanks for the tip, I use PM but needed to toggle the Comet & Media Fusion ON.
Question, is there a way to limit link size? I looked up and down the POV settings and could not find anywhere to do it. I use links under 10GB normally. Thank you.
Thank you. I will try that after I get home.
Yes you can limit searches by size.
Go to the results tab and then go down to the sorting and filtering area.
Limit by file size is one of the options and you can limit the size to under 10 GB or 10000 MB
That did the trick!
Was that in TP’s instructions and I just somehow missed that step?
I saw that and the “default” was 10000 but I was getting links way larger than that. I clicked on it, changed it to 5000, 6000, 7000 and it did limit the links so I put it back to 10000 and it’s perfect. Thank you.
My Kodi settings seem to always have Torrentio and Pirate Bay toggled ON so my initial install and links pulled fine. I did toggle ON both Comet and Media Fusion though which were OFF. Those seem to be the big 4 to make sure are on. Thank you.
On a different note, all my NEW AND REVISED Kodi settings from that kick ass Kodi set up video have disappeared back to the default settings on my ONN 4K Plus box. They lasted a day or 2 now poof. Disappointed.
The issue you are seeing with Monitor Dot is a Surfshark issue.
Please see this page for a possible fix for the issue:
SurfShark - VPN Monitor Dot
New KODI question…do the repositories and add ons within the repos sitting in our KODI downloads continually update even if we don’t have the add ons “added” to our system? Does that question make sense? Should we ever delete repos out & re-download them to get the latest most up to date version? I do that occasionally when add ons get wonky and it’s pretty easy to delete and re-add them. Thank you.
If you go into the settings most addons have the Auto update enabled. No need to do any manual updates. and when I open KODI I always wait a few seconds for the updates to flash across my screen
I have auto updates toggled on for each add on in addition to the main auto update setting in the KODI platform. The reason I asked is that from the 3 different streaming boxes I use, I look at “recently updated” on all 3 and rarely do they match add on to add on, box to box. Sometimes “Umbrella” will flash a message that “an update is available” but it doesn’t immediately auto update.
As with most electronics, occasionally stuff happens with no good explanation why. :laughing: !
Thank you, Mark.
I tried to get the ONN 4K Pro working, but haven’t been successful with setting this up in Canada. I’ve tried using my hotspot with Surfshark to change my location to the USA and couldn’t get it to work. I have been looking for a setup tutorial, as I am a person who is visual and need this to include step by step instructions, so i can pause and rewind what i seem to always miss. Maybe I am just overlooking some steps.
Sorry I don’t use a VPN so not sure how to assist with this. There have been several posts here about setting up the ONN 4K Pro in Canada using a VPN and Hotspot, Try doing a search or maybe someone else can assist
Okay, thanks for the response and will look for more information.
Please take a look at this thread. it should get you going.
Thank you and I will look at this post.
