Hopefully you have rebooted your router modem.
In network settings on your Firestick remove and forget your WiFi settings and then log back in and set WiFi up again.
I canāt recommend something Iāve never tried. Only use 4k pros and a new BuzzP6U. Still setting up the buzzā¦
Everything was finally going smoothly for a couple weeks and then it died again. I couldnāt get Kodi to do anythingā¦force quit => nothing, cleared the cache => nothing.
So, I broke down and bought a NVIDIA Shield Pro box. Iām just now setting up Kodi again on it. Wish me luckā¦Iām hoping this solves the issues I keep having.
Any recommendations on which build/add-ons to go with? I have a real debrid account.
thanks all!
I used the new video on the Kodi addons page for installing Umbrella and all the best live TV addons. Working great for me. I would agree that Umbrella is the best addons out there right now.
Iām sorry to hear that the Fire stick gave you more grief. Iām fairly certain that many dumped the stick because of the issues that you were having.
Congrats on the Nvidia Shield Pro. Iām fairly certain that you will like it. I LOVE mine!
Anyhow, here is a link to the YT video that I used to set up my Pro. The guy is real easy going, just like our own Jayhawks359 with his Kodi setup video here on the TP Insider..
https://www.youtube.com/watch?v=g9s-2qqsKeQ&ab_channel=LeeTalksTech
You are jokingā¦right??
Youāre doing it wrong
Just received the email with the Enigma build only for it to be an empty file. Anyone having this problem?
I have 100 service. And surfshark wire guard, getting 115 I believe itās confusing optima onlines throttling.
I was just following your guide for doomsday build setup and when I got to the build menu the option you advised is not there. There is no build matching the tutorial and when I try the only one similar, it fails and says check log for more information. I tried the Doomzday OMEGA Builds.. version 21.2
Pretty sure itās failing because itās not the right one. But the one in your screenshot from the tutorial is missing from my list of optionsā¦all of them matched until I got to the one I needed. Any idea where I can get this build to finish?
After dinking around with Stremio the last 30 days, I absolutely love my Kodi performance with Surfshark, Trakt & Premiumize. It works flawlessly and Surf does not slow down my internet speed. I wanted to like Stremio but Kodi just works so much better for me.
For some reason, the changes I made per the excellent Kodi setup video, are not holding on my ONN 4K Plus and every time I go in and out of Kodi, it reverts to the original settings. Help! I want to smash the box.
I think I somehow got corrupted. I deleted KODI and started anew with only The Crew & Homelander. Iām not installing Monitor Dot this time. It annoys me as it POPS UP everytime I turn on the ONN Box and I couldnāt stop it. I figure if the SURF SHARK KILL SWITCH is ON then Iām safe or the internet wouldnāt work to connect KODI.
Iām starting to think thereās something about those Onn boxes that doesnāt like Kodi because this has happened to my dad before a couple times and I canāt figure it out.
The settings are within KODI and donāt have anything to do with the ONN 4K or any device you are using. When you are going into the various sub menus in KODI and changing things are you also making sure you hit okay or done after making the changes. Itās a pet peave of mine and that used to happen to me as well
I donāt know if itās the same issue or not, but I feel like my dadās issue is the GUI resetting randomly. If you change the skin back to what it was set on then most of the time everything goes back to the way it was. But he has had a time or two where it went back to stock. Although I canāt confirm that he didnāt accidentally clear the data instead of clearing cache from the app.
Same issue mentioned hereā¦
Good to know Iām not crazy lol
Me too. My Fire TV Cube is perfect in keeping the settings. My ONN held the new settings for a few days I THINK. We will see how it goes later today when I turn it on.
I am returning 1 of the 2 ONN 4K Plus boxes I got. Iāll keep 1 to play around with and the other I never even opened.
I just installed POV and all the settings from yesterday are still there so they are holding for now,
I like POV, itās fast. Since this is adding add ons from yesterdays KODI RESET, Iād gonna check add ons out I donāt use and POV is gonna be my go to for now on the ONN box.
