Kodi & Addons Loading links/Not Playing
Did you check your RD account under “My devices” to make sure your device/addon is linked? What about Umbrella or other addons?
RD is encrypted so i don’t think your ISP is blocking it. But i could be wrong.
I use a vpn but i am pretty sure you dont need it with RD.
I’m trying to figure this out but cant replicate your problem. I am using a Troy 21.1 fork with only The Crew installed.
You are going to Tools in The Crew and then ResolverURL and then Universal Resolvers2 and then down to Real Debrid (under Premiumize.me) , right?
I have selected (Re)Authorize for RD and others and get the popup with a code everytime. I dont get sent to the previous page like you do. What previous page are your referring to?
Here is the problem it seems. No idea why this is the case with you.
I am still suspecting my ISP since it was the exact same symptom on Both of my devices at the same time.
I say ‘was’ because the problem is resolved. A complete Uninstall/reinstall of Kodi & The Crew. With that I still could not (re)authorize my RealDebrid.
Because of that suspicion, I installed Surfshark and all operations returned to normal. However, on my 2nd Firestick I installed the VPN first, but the RD symptom remained. After the reinstall of Kodi & The Crew, everything is back to normal.
Has anyone out there experienced this kind of (maybe?) interference from an ISP? I can’t imagine that that is really what happened.
Well I’m glad you found a solution.
I guess for whatever reason your ISP may be blocking access. Who is your ISP? Others may be able to help.
Do you have any type of security procedure with them. Its possible they may have flagged it as suspicious and you need to verify it.
But if the ISP allows you to access the website to pay why would it stop you from other access?
Not sure but hopefully someone else has insight.
One other point I just observed. All along I’ve seen that my Firesticks both only had about 600MB out of 5GB available. After the uninstall and reinstall, I now have 2.5 GB available. All I have additional on my Firesticks is Kodi and Smartube. And now additionally Surfshark.
Ok. Maybe a clean out of your cache was the issue too. I havent used a FS in a while. They can get overloaded easy.
As of last night Kodi/Crew will not grab any streams. It just runs down the entire list of streams, selects none and shows no stream available. I also installed Seren and got the same results (none).
(I try to use the search feature on here but only get hits from years ago. What am I doing wrong? Is it because I’m not a Patron? )
This is happening on both of my Firesticks. The Kodi webpage shows many reports of Kodi being down, but not what to do about it.
Any suggestions?
Real debrid has, for most of us, stopped providing links due to legal issues. Check the other links on TP for more info.
Some people say it is still working for them but not for most of us. Maybe eventually it will stop for them as well.
Troy is recommending Premiumize.me but you can also try Alldebrid.
Or you can use a nob debrid addon like Elementum.
I just posted the same issues.
been using 21.1
And I just last week paid for a 6 month RD subscription!
I had been using Real Debrid for the past year and then it stopped because of the problem everyone is discussing.
I signed up for a free 7 day trial of All Debrid.
It worked fine for part of today, but then stopped giving a message about limit of 1000 magnets reached. I have no clue what that means or how to fix it.Premiumize seems pretty costly by comparison.
Sorry i have no idea. I dont use Alldebrid.
If you login to RD and open a ticket, you can request a refund if you didn’t use the service.
I didn’t know about the problem and I renewed but I was given a full refund because I was unable to use RD.
I’m having the same problem with the crew and seren. I have been shows in my favorites and have been watching them all year. Yesterday when i clicked a tv show, the season and episode it goes to providers. I pick one snd it does its thing then shows no stream available. I try most of them and same error appears. This happened a few months ago but cleared itself after a couple days.
My real-debrid is good till middle of December . I hadn’t changed anything is any of the settings.
Any suggestions?
When this happens to me the only solution I’ve found is to force stop all apps & addons, clean out the caches then restart my device. This has worked every time on both my Onn 4k and Onn 4k Pro.
Just a crazy question, are you using Real Debrid? If so you might want to check the significant number of threads regarding the current state of Real Debrid.
I’m having similar problems as well. Using the newest version of KODI w/the crew addon.
Everything was working fine until just recently. It’s able to find all kinds of streams, but then it says something about no streams available. It does this in Stremio and Cinema.
My download speeds are 103 down. I’m using a T95Z or whatever it’s called. Real Debrid is up to date.
Can anyone help?
Mark posted this recently in another thread.
I wasn’t certain, in your post, whether you are also having the same problems Stremio and Cinema. Is that the case?
Yes. Both are showing a lot of streams only to show there isn’t any.
