Kodi & Addons Loading links/Not Playing
That was the first thing I reconfigured when I purchased my Tp-Link.
Appreciate the reminder for sure.
Thank You Crossx77
I have the same issues = even re-installed Kodi= worked for 2 days, now nothing= just the working icon
clear cache maybe that will work
thanks - done that - about to give up on kodi - running tivimate - went to kodi 21 when issues started
KODI 21 has been working great for many months. What is the specific problem you are having? Are you using a Build? Addons? which Addon(s)? Umbrella has been Flawless
I use Kodi with RD daily without a single problem. I use 3 Addons. Coalition, The Crew, and Dradis. All work flawlessly as MarkxG stated above.
You can also download Kodi from the search mode on Firestick.
I built from the Estuary skin that Kodi provided and installed the supporting programs Trak, Real-Debrid, A4k subs and Trakt support from the Kodi repository and I ave never seen Kodi load more rapidly and efficiently.
The only issues I ave ever had are with some of the addons themselves not being compatible with Kodi or not properly installed.
Fenlite, Infinity, Umbrella, Coalition are my go to addons and ave worked flawlessly. I mostly use the Fenlite but love some of the different programming these addons independently provide.
I think that keeping it simple & staying away from the larger builds are the way to go. The builds simply have far too many working parts and when not maintenance or updated there can be many failures.
When one goes thee entire build goes.
Almost always the case that Real Debrid expired or needs to be re-authorized if you are seeing the links but none play.
I religiously clean out my downloads from my Debrid account and refresh my accounts Once every two months depending on usage.
Idk what you mean by “refresh”. Have you renewed the subscription? When you log in does the box at the top tell you how many days you have remaining or does it say expired?
Reauthorized…My Real-Debrid is active until January.
So this original problem was resolved then?
I am having the same issues as well. I will be watching a series with no issues. I go back later to continue and they wont play, so I click on the episodes I just watched and they wont play either. I go back in a few days and they work again, and sometimes not.
It’s all of the Streamers to. Syncler, Kodi, WEYD, Stremio, and I seem to be getting lesser Links with Real-Debrid.
But yes, I’m having the exact issues even after going to my Real-Debrid account and cleaning out my downloads.
I use to be able to watch any of the Mountain Men episodes and none of them are playing now, nor are Port Protection and Life Below Zero.
Did you share your Real Debrid account with someone else? If you use the same account on two different networks at the same time your account will get flagged and you’ll have to contact customer support. This is the only other thing I can think of if you’re absolutely sure that your account is not expired and you have reauthorized it. Especially if this is happening across all the apps you are using Real Debrid with. Unless your ISP is blocking it. Have you tried a VPN?
No…
No one else has my account info.
I change passwords weekly.
I agree 100 percent, I had nothing but trouble and really slow reaction with those builds specially the big ones, simple is best.
Had similar problem with an addon I recently tried, wouldn’t play anything from git go, would say no stream available. Cleared the cache and providers in the tools section of the addon, then it worked.
So true…
Keeping everything clean and refreshed helps billions…
Especially on our Real-Debrid Accounts. Our Downloads need deep cleaning as well.
