I’m using the original Kodi 21. Estuary skin. Everything was working well until my Onn 4k Pro updated. Elementum, afFenity, OneMoar, Crew were all streaming with no issues until my Onn 4k Pro updated. Everything loaded, the sources shown, but would not stream. My Weather service MultiWeather also stopped working.
I removed Elementum and everything started streaming again. My Weather service however hasn’t. My older Onn 4k device however is still running the multi-weather service in Kodi.
Glad to hear your streaming again. That weather service does that to me. I uninstall it, load it again. Log out of Kodi, then log back in again. Some skins the weather service seems to mess up.
My RD links are now listed as “Uncached Torrents”. As a result I can not watch them…But I also use “AllDebrid”, as a back up. “Alldebrid” is giving me “Cached Torrents” and I can play them.
Any addon I have used, under your URL Resolver where you authorize your service, should be a choice to get cached torrents. I use Real-Debrid, so I don’t know about All-Debrid. My current addons are The Crew, Dradis, and Coalition.
Same thig has happened to me.
After doing loads and deletes’, and reloads and setting everything back up, it still won’t play. So I deleted Kodi and installed Streamio and now I’m happy
08/06/2024
Everything was running great last night and since the same issue back in early June. Tried loading multiple programs from all four of my addons and although the links are appearing. Nothing is playing. These are exceptional addons. They have given me no negative issues loaded quickly and have never had an issue with them.
This happened before and the culprit was Elementum. After uninstalling that configuration everything has been working great since June 2cd 2024.
I have spent the past 4 hours disabling & enabling addons trying to make sure its not an addon causing the problems, and are now thinking it’s my Onn 4 Pro device after getting an update yesterday evening.
I have no idea what else it could be. I keep getting a popup “No Stream” on all Four addons on multiple programs despite having a large selection of links?
I’m also having issues with Kodi loading on my older Onn device when making it’s first run. It’s loading terribly slow. I have the Fen-Lite/The Lab & Crew on it.
However. All the addons are working as they should from there.
Why would the addons work on the Onn device but not the Onn 4k Pro?!
Anyone else having these issues?
Thank You Ever So Much
Jeffrey
Device: Onn 4k Pro
304 Mbps Download / 15 Mbps Upload
Addons enabled:
The Lab
Fen Lite
Infinity
The Coalition
Although I don’t use Kodi I have 2 thoughts. Sometimes if using a VPN with a killswitch updates may trigger that and interfere with programs. If using a vpn then shut it down and restart. Also, after the update did you reboot the device? Just guessing here @jericho777
Is your Real Debrid subscription active or has it expired?
Going to try that now will update momentarily…
I have Stremio, Weyd & Syncler on this device and those programs are playing with no issues.
Will give your troubleshooting advice a go for.
Thank you much Miki
Everything is up to date. rebooted router and shut down modem/restarted.
Did as you instructed.
Also rebooted the Modem, Router, Smart Tv, and the Onn Pro device and everything seems to be working in Fen Lite. Will try to play the other addons and see how they do…
But I’m confident they’ll be fine. Everything loaded quickly and the Program started right up after selecting a link.
I have come so close to abandoning Kodi, but I have a simple layout, Estuary skin no fancy build with the 4 addons and it’s a great backup and I love that the programing has loads of information on the shows and cast…
That’s a huge plus for me, otherwise I’d stick to my Stremio, Weyd and Syncler and dump the Kodi…
My most gracious appreciation Miki & MarksG for your quick response and help. Saved me hrs more troubleshooting this issue, which is a great learning tool as well. ![]()
Thank you both so much.
Jeffrey
Just an FYI I’ve been using the Umbrella Addon in KODI for several months now. It is Lightning fast with the Cocoscrapers and delivers perfect 4K/1080P streams with RD. It’s the best Addon I’ve ever used.
Often the issue you refer to is caused by a failed “stack” IO issue that did not “clear” or resolve and so you can only get to that “stuck” part and never past it. With a reboot and complete restart/boot of devices this is usually cleared. Nice going and congratulations. Good work. Jave a wonderful day.
I’ll give that a go… Haven’t used it yet.
Thank you…
Always learning man and you guys are such an awesome help getting over the hurdles man.
Always appreciate you guys & gals…
Y’all have a great day and again, thank you so much.
You are always welcome. Makes my day to be able to successfully help someone. Be well @jericho777
Might sound crazy but have you had a new router recently? In the UK they sometimes ship them with the built in firewall restrictions on for child safety so things like adult sites & streaming won’t work unless they are disabled. Might be worth a check.
He seems to have it fixed. 5 posts above yours.
The Umbrella addon is working like a charm. And you’re right, uploads fast and supplies many 4k and 1080 links.
So appreciate the heads up.
Y’ll enjoy and thank you.
You guys saved me a lot of hrs troubleshooting.
Everything is working great and all the addons are awesome.
Y’all have a great evening, stay dry ifn you’re in the path of Debby.
Gods speed and Thank you so much.
Great Job.
