Kodi add ons not finding tv shows
I’m getting the same problems that you are all getting.
I’ve been using my android TVs and have gone back to my firestick 4k max. It’s all working fine on it. So can’t understand why it’s not on my android TVs.
It’s wierd
I had some issues with all of my real-debrid associated add-ons. I opened my real-debrid account and looked at my devices. There was a lot of clutter there. Every time you authorize a device for real-debrid there is a saved entry on the device tab of your debrid account. I deleted all of those entries, unauthorized real-debrid on all of my debrid associated add-ons, then went back and re-authorized the add-ons that I’m currently using. Real-debrid now works quickly and cleanly on all my add-ons that use it. Hope this helps you.
@brianh76 thanks for that. I have done that too, and it just keeps doin it. It’s almost like it is when debrid goes down. I’m going to try what Jayhawks said, add my favorites to trakt collection and remove favorites. Suggestions are welcome thank you
I solely use The Crew with Kodi and never have any issues. Now that I’ve also downloaded the newest version of Cinema from Troy point I have no issues there either.
Same here. Seems odd, if it’s because they want payment, they should make that known. Instead of letting us think there’s a problem.
Then what are we doing wrong?
Same issues here. I have 20.1
@hvacman69 they keep saying we’re doing some thing wrong but I’ve been doin this long enough I can usually figure it out , nobody wants to seem to give any remedies or possible remedies. I did download from Kodi this time.
Exactly, over the last yr something has changed. I stopped getting Ted Lasso after 3 episodes, just stopped, same with some other popular shows!
I wish I knew what your problem was. You keep saying you are doing Fresh installs of 20.2 and then the Addons. I don’t know why you are still having issues. I’ve been using KODI for many years and I use a Build that has been solid for at least 5 years. But problems with Addons have nothing to do with a build. I know my way around KODI fairly well but when you are doing Fresh installs for both KODI and Addons and still have issues I am at a loss as to what is going on on your end when everything is working perfectly for me
was having the same issue then installed base 19 must have redebrig after install everything worked as did crew
Are you using RD? I do not.
Yeah that’s your problem right there. You are going to struggle to find playable streams without RD on KODI. It’s very cheap. If you are not going to use a premium Debrid service then IMO you are wasting your time with KODI.
I think I’m going to try 19 again !! I’ve had crew forever with real debrid.
Thanks for your input. I will take it to hart.
I use Scrubs 2, dont use real and have no problems with new tv shows
Downloaded Diggz xenon. Use scrubs …for downloads no need for debrid…
I use Scrubsv2 for free shows it works perfectly fine, I don’t have real debrid, .
Same here downloaded troypoint tool box downloaded KODI 20+ troypoint recent version then down loaded Diggz xenon and use the scrubs 2 add on …for tv movies …Also downloaded KODI Superman download which has crew add on and other etc have trouble downloading recent movie tv their …
It’s so weird that so many people have 0% functionally and so many have 100% functionality. I get zero sources for current shows, but now seem to get tons for really old shows. I have tried every setting, every trick, every auto and manual fix; nothin’. I’ll keep tinkering - hopefully one of us cracks the mystery soon.
