@MarkxG i have reinstalled Kodi, 3 times, crew, seren, and fen. I have set up crew per Jayhawks instructions like I have for past year! I still get no stream, no results on a lot of programs… I’m not too sure it’s on my end, when I’ve never had this problem before, and I’m seeing a lot of folks putting up the same issue. Hard to convince me it’s all on our end on every add on. Downloaded cinema and all programs there and I haven’t integrated RD yet. !
I’m not sure about all the Addons but there are no issues with KODI 20.2 and The Crew and 9Lives. I don’t know (and really don’t care) about other Addons as these 2 have been working flawlessly for at least 6 months assuming you have RD
Be carefull it has 2. malware virus check there’s so many other ones cuz they add on you can go on trade points and ask for Cody addons I practically like promise and magic dragon oath for dynasty good luck
What has 2, this is a bit confusing
No TV show links when there are plenty of movie links has been a recurring issue for years. I forget the solution but spend a little time googling it and you should come up with the resolution.
I was getting everything on The Crew but lately I can’t much of anything.
Me too and I have real-debrid.
Every program I try keeps coming up with “One or more items failed to play. Check the log for more information about this message”. What does that means?
20.2 available need to update, believe seren is no longer updating
The issue is on your end. Why are so many having issues with The Crew? It works folks. Start over with a Fresh install of 20.2
I don’t understand this either. I’m getting hundreds and hundreds of real debrid streams on most programs (admittedly, not may free ones). Of course, I don’t get anything on old, obscure programs because they just aren’t out there.
I’ll say this one more time. I have installed 20.2 3 times now, then installed crew 3 times. Have set up crew per Jayhawks instructions. I’ve been using crew for over two years. And it’s not just crew if you look at all the posts. It’s just about every add on. I finally downloaded cinema and all the programs I’m trying to watch are there with tons of real debrid links. I never had any problems til 20.1 and 20.2. Don’t know what to say but seems like I’m not the only one.
And I’ll say this one more time as well. Sorry you are having issues but whatever they are, they are on your end. There is absolutely nothing wrong with 20.2 or The Crew.
I am having the same problem with 20.1 and The Crew. No streams available but shows many Real-Debrid links?
@G-Man yep many are, but can’t get fix for it. You can only reinstall so many times
Working fine on Kodi 20.2 using Crew with RD on Cube. Where are you installing from? I’ve been using Green Monster build for a few years. Just works.
Twilight is a great add on.
Fen is no longer updating so Twilight is very similar to Fen. I’ve been using it and had no problems. Use RD with it.
Installing from troypoint , but I just tried from a Kodi site this time around.
Not sure what’s going on but Fen, Promise, Twilight, Ezra are just a few addons I’ve used in the last week with RD on 20.2 and I’m pulling tons of links for movies and tv shows.
Don’t force it, use a bigger hammer
@PapaS I’ll give some add on a shot. Fen was working great then the crew and fen started doing weird crap. Like what the other fellas and gals have been saying
