Is anybody else having a problem getting there add ons to find current tv shows. Using Kodi 20.1, Fen, and seren. Real debrid. current. Suddenly won’t find episodes 1 week to a month old. I’ve had nothing but issues since updating to Kodi 20.1 Thanx
im on 20.2 kodi no problems a lot of people are having problems with those addon try using onstream or uk turks
Try using Addons that work. 9Lives and The Crew have been working flawlessly for several months
Last nite totally removed everything. Uploaded 20.2, crew, and seren. Too late to check out after setting up crew thanx. Not familiar with 9lives
I have been getting a ton of “no streams available” messages from The Crew add-on on KODI (newest version)
Do you have a real-debrid account??
I may try 9lives after reading about it
Never have in eight years of using KODI. This is a new development on all of my devices (2 amazon and one onn). I am on Surfshark however.
That could be your problem. Crew and then have steered away from free
I can’t get tv shows on Kodi addons like The Crew and The Promise. When I select tv shows, all that shows is two dots. The movies work perfectly. Why do the movies work but the tv section don’t? Is it because I am using Kodi version 20.2?
KODI Movies/TV Shows working great on The Crew on 20.2. whatever the issue is it’s on your end. I suggest doing a Fresh Install of KODI 20.2 (Can get that in Troypoint Toolbox) then reinstall your addons and authorize RD.
Thanks MarkxG. Will give it a try.
@MarkxG I can’t get anything new shows or seasons from end sept to beginning October on crew. No stream , and I’ve re authorized twice. One program is all I got. Crew was never this far behind
Not sure what to tell you but the issue is on your end. Assuming you have RD? If not you need it. I suggest doing the same suggestions I gave to animal above and get a Fresh install of 20.2, resinstall The Crew, and reauthorized RD. I am not having any issues so not sure what to tell you
@MarkxG I just did everything last nite, real debrid authorized twice , I’m getting tired of re installing everything to be honest. Are you getting programs that started last week. I even tried to watch what I watched last week and it wouldn’t bring it up. It’s strange
I have had issues with Seren with TV programs. Try using “Shadow” addon…works for me and still gets updated.
I’ve been getting all current episodes for all my shows for months.
I am running current shows on crew fen and seren. Did you try resetting firestick back to factory settings? This may help if you have not already tried it.
No, I have a fire tv (old) on my other tv. And I get some programs and not others. I get episodes then it’s like they’re taken off air. It s identical on both fire tv and fire stick . I don’t know what’s goin on. Use crew , fen, seren. Fen was workin great and it started this too. On some I’ll get free providers no RD, then I’ll get a whole page of RD. I may go back to Kodi 19. Never had issues til 20
There is no issue with KODI 20 it is on your end. And if you go back to 19 you will find less Addons with streams as most of the working addons are now optimized for 20
